Keep each device's sync separate
This is a discussion on Keep each device's sync separate within the iPad General Discussions forums, part of the Apple iPad Discussions category; I have had my Ipod Touch for some time now and collected quite a few apps. My wife just got her Ipad and when I ...
Results 1 to 8 of 8
    17702
    Oct 2010
    Question Keep each device's sync separate
    I have had my Ipod Touch for some time now and collected quite a few apps. My wife just got her Ipad and when I connected it to our computer, ITunes started putting all my Touch apps onto her Ipad, which she was furious about. I then had to delete them all one-by-one. So how do I keep the apps sync'd to the one computer separate for each device? Thanks.
    iPad Addict
    6630
    20 times
    Jun 2010
    1,189
    in your itunes , with your ipad connected. hit ipad on the left column then hit the "app" tab. you could check the apps that you only want. then sync it.
    Fate is not by CHANCE but by CHOICE.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    There are a couple of ways to incorporate multiple Apple mobile devices to on computer. Here is an article from the Apple website. See if one of these might work for you. I am thinking that the third method might do the trick! (It says "multiple iPods", but these methods will work with an iPad or iPhone)
    How to use multiple iPods with one computer
    At our house, the solution was simple... two computers!
    17702
    Oct 2010
    1991-C4, Tried method #3- my Touch apps still try to sync with my wife's IPAD. I might have to get her to log onto our computer with her own Windows profile but can I still have the one music library? Thanks.
    Banned
    15633
    Sep 2010
    118
    have you checked the manual?
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Quote Originally Posted by JDMils View Post
    ...but can I still have the one music library? Thanks.
    You can still "cherry pick" what stuff from the library goes on to which device. Probably the easiest way with music would be for each of you to create your own playlist and only sync those playlists to the appropriate device. With things like apps, books and movies, etc., you can put a check mark next to each one you want by selecting the appropriate tab in iTunes.
    iPad Enthusiast!
    13502
    Aug 2010
    Sunny FL
    36
    I use two iphones, an ipad , andntwo ipod touches on the same computer. They all sync completely and seperately. They all have different names and of course different content.
    The solution is simple. I couldnt stand using itunes until i finally picked up the phone and called apple support.
    Windows allows you to log in with seperate users. By setting up seperate users on your computer, your i-devices will sync seperately and not recognize or try to sync the other devices.
    Not to get too simple, but for example:
    Windows user Seans iphone for my iphone
    Windows user ipad for the ipad
    Log in to the correct user, start itunes, sync up, close itunes.
    Then log in as a different user, sync the appropriate device for that user.
    Yada yada yada.
    Hope this info helps.
    BBSean
    17702
    Oct 2010
    I ended up creating a new user on my Windows machine for my wife to sync her IPAD. I also used the information provided by 1991-C4 to point her library to mine so that we both had the same music to choose from. I just wish iTunes was a little more smarter in being able to create Profiles for each device so that we could choose which apps, music, photos, etc could be stored on respective devices without having to manually alter sync details. Thanks all for your help.
  1. Second device same app purchase
    By BrennB in forum iPad Help
    Last Post: 12-26-2012, 09:22 AM
  2. iTunes: How to change sync settings without connecting device?
    By xlar54 in forum iPad General Discussions
    Last Post: 06-19-2012, 12:24 AM
  3. Just another i Device lover.
    By Pixelmonsters in forum New Member Introductions - Site Assistance
    Last Post: 10-04-2010, 06:03 AM
  4. Device low in memory!
    By deoknam in forum iPad Help
    Last Post: 06-10-2010, 05:24 PM
how do i separate itunes by device?
how to keep apps separate
how to keep iphone and ipad apps separate
how to separate apps for iphone and ipad
how to sync itunes separatly
how to synch separate devices ipad itouch
keep ipod and ipad apps separate same itunes account
keeping ipad and iphone apps separate
separate ipad and iphone sync
separate sync iphone ipad
sync iphone and ipad apps separately
sync iphone and ipad separately
