do i have a deffective battery?
This is a discussion on do i have a deffective battery? within the iPad General Discussions forums, part of the Apple iPad Discussions category; hi, i got myself a new ipad last week. it seemed to be discharging quite fast so i decided to do a battery test.
here ...
here are my movie playback results:
- 5% battery loss after 20 minutes of movie playback with sound muted, 100% brightness.
do you guys think something is off? or do you guys also get the same drainage?
10-08-2010 08:57 PM
iPF Super Guru
The batteries in the iPad have proven to be pretty reliable (so far!) and have been living up to the 10 hour (average) use time, but what has been known to be a little "flakey" at times is the battery usage indicator!
This is why Apple suggests letting your battery drain to the point where the iPad shuts off then recharging it to 100% to re-calibrate the battery usage indicator.
From the Apple website --
How long does it take you to totally run it down to zero?
iPF Super Guru
The correct answer is, "As long as it takes!" It all depends on how much battery you have left when you start the process. To intentionally run the battery down, I usually start one of my streaming audio apps (like PocketTunes). This does two things: It keeps the screen on and maintains constant WiFi activity - two things that use the most power (except for 3G, but I don't have that on my iPad).
ok i will run it down to zero and let you guys know.
iPF Super Guru
You may need to set your Auto Lock in Settings to Never so your screen does not shut off.
Damn...I didn't know this! I always top it off and rarely get below 30%...going to drain the sucker now with clock radio.
ok 7 hours into a movie playback and my batter is at 10%. i doubt that i will make 10 hours advertised by apple. do you guys think apple will still exchange this device for me. i bought it 10 days ago... i don't really have time to send it to service because i will be out of the country in few days.
UPDATE: ok 8 hours and the battery has 3% left with no volume. is this expected?
iPad Guru
Originally Posted by
matt_90036
You must have the brightness CRANKED! I keep mine at the lowest brightness and get about 14-16 hours out of it. And thats listening to music, watching movies (netflix, air video) browsing, email, chat, etc.
When I'm working I use it all day while I work so I charge every 2 days...sometimes nightly depending on how long I can use it straight or how long im working.
When I'm not working I charge it once a week.
gentlefury
matt_90036
yes i do have brightness at 100%. but is apple's claim of 10 hour battery life on 100% brightness or something lower? am i just be paranoid here or do i have a battery problem (8hours video 100% brightness with muted volume). i want to be sure because i have 2 more days to return this thing.
- You may not post replies
- You may not edit your posts
Forum Rules
By Al Rogers in forum iPad General Discussions
Last Post: 07-17-2010, 05:59 PM
By crimlaw in forum iPad Help
Last Post: 07-15-2010, 10:33 AM
By mossman in forum iPad General Discussions
Last Post: 05-09-2010, 07:46 AM
By emilyjane918 in forum iPad General Discussions
Last Post: 05-04-2010, 10:14 AM
By Sincere11105 in forum Off-Topic
Last Post: 05-01-2010, 07:57 PM
