iPad battery life drain after using Google Chrome
This is a discussion on iPad battery life drain after using Google Chrome within the iPad General Discussions forums, part of the Apple iPad Discussions category; Has anyone else noticed a connection between Google Chrome and battery drain? There were issues with Chrome draining Macbooks and iOS 6.2 battery drain. I'm ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Spugnut
Thread: iPad battery life drain after using Google Chrome
    78692
    Jul 2011
    8
    Has anyone else noticed a connection between Google Chrome and battery drain? There were issues with Chrome draining Macbooks and iOS 6.2 battery drain. I'm been seeing more drain since using Chrome instead of Safari these last few weeks. This happens with two iPads I have, an older iPad 2 and a new iPad Mini. Also, noticed overnight drain of 10-20% and new Chrome usage is common change. I'll try killing the Chrome process as well as other unused apps and see if that improves things. Are there other battery drain apps that may be responsible?
    153195
    3 times
    Jan 2012
    east islip
    203
    it should not drain 10-20% overnight do you turn off wifi and chome when you put the ipad to sleep mode
    78692
    Jul 2011
    8
    Quote Originally Posted by tazz3 View Post
    No, never had to manually turn off wifi or apps before. Just pressed the sleep/wake button to turn off/sleep and the home button to turn on. Been working fine for 2 years now on the iPad 2, and would have just thought it was an aging battery if not for similar effect with new iPad mini. Killing the Chrome app seems to prevent the overnight battery drain. I'm thinking that Chrome is doing a lot of sync in the background and maybe even when in sleep mode.
    Some folks are having battery life issues with 6.1.3, but some of these are improved when chrome sync is turned off, so I will have to try that.
    https://discussions.apple.com/thread...t=510&tstart=0
    145622
    6 times
    Jan 2012
    South Africa
    144
    I use both chrome and Safari, and did not experience battery drainage as you described.
    ShortBus likes this.
    Sent from iPad 32Gb 4G/Wi-Fi via IPF
    78692
    Jul 2011
    8
    Quote Originally Posted by Spugnut View Post
    Do you sync with your desktop and other Chrome browsers? That seems to be the issue in my case. Don't know if it's constantly syncing when asleep or only while the iPad is being used, but I found some macbook/chrome battery issues that sounded similar. This is just one that seemed to be traced to some graphics chip software bug: Does Google Chrome use a lot of battery? - MacRumors Forums
    275558
    5 times
    Jan 2013
    Jacksonville, fl
    40
    I have google chrome and use it for all my web browsing.... I get around 11 hours battery life and only maybe a 3% drop over a a 24 hour cycle
    78692
    Jul 2011
    8
    Quote Originally Posted by ShortBus View Post
    Strange. So you are using sync between your other devices like desktops and laptops? Or are you only browsing with your iPad? BTW, which version iPad? 11 hours is great battery life!
    Anyway, now that I've killed Chrome and am using Safari only, the problem seems to have gone away. I'm a little afraid to try Chrome again, but will if there's a need. Hopefully it's just an intermittent problem and/or it gets fixed in next version.
    275558
    5 times
    Jan 2013
    Jacksonville, fl
    40
    Quote Originally Posted by inbox788 View Post
    yes I use sync with my laptop phone and iPad. i have an iPad 4 with iOS 6.1.2 jailbroke. never have issues with battery life.. I keep do not disturb on so I don't get duplicate notifications from apps with my iPhone
    Tapatalk'd iP5
  1. iPad Battery Drain
    By SallySparrow in forum iPad General Discussions
    Last Post: 04-26-2013, 07:00 AM
  2. ipad 3 battery drain to fast
    By zahi in forum iPad 3 Forum
    Last Post: 09-22-2012, 02:16 PM
  3. IPAD 3, Not charging after battery drain....
    By waffles07 in forum iPad 3 Forum
    Last Post: 06-19-2012, 08:18 AM
  4. Battery Drain On iPad-2
    By Ayoade_Page in forum iPad General Discussions
    Last Post: 12-24-2011, 02:54 AM
  5. Jailbroken iPad (4.2.1) not rebooting after battery drain
    By radumarinescu in forum iPad Hacking
    Last Post: 06-17-2011, 09:59 AM
chrome iphone battery life
does google chrome drain your battery
does google chrome for iphone drain battery
does google chrome use a lot of battery power
does using google chrome on iphone kill battery
google chrome drains battery life iphone
google+chrome+for+battery life
using google chrome on ipad drains battery
