Help Using I-Tunes Make Folders & port PDF
This is a discussion on Help Using I-Tunes Make Folders & port PDF within the iPad General Discussions forums, part of the Apple iPad Discussions category; Does any one have the time and patience to step-by-step me through the process of creating a folder or folders via I-Tunes and port PDF ...
Results 1 to 8 of 8
    14779
    Sep 2010
    daytona beach fl
    130
    Does any one have the time and patience to step-by-step me through the process of creating a folder or folders via I-Tunes and port PDF files over from the hard drive to the I-pad device?
    I successfully dragged some PDF files from my hard drive to the books icon in I-tunes and they showed up on the device in iBooks. However, I will be dealing with scores of files/letters that are presently in folders on the hard drive. Each file (letter/lesson) has its own name. Perhaps 20-30 files are then in a folder categorized by date/year ... eg., 2010 ... 2009. In IBooks, the icons are so small I cannot see the name of individual files.
    These files really need to be in folders on the device. I was unsuccessful in Itunes in trying to drag the entire folder to the device.
    I have installed IBooks, IAnnotate (PDF) and GoodReader on the Ipad. If something else is needed, I would gladly go to the store and get it.
    I am really dead in the water at this point at any attempt to use the I-pad in my class room until I can get my lessons in some semblance of order.
    Could someone please help
    Jer (one half of the jerliz team)
    iPad Enthusiast!
    7850
    Jun 2010
    51
    I add PDF files like this go to file > add folder to library > select folder from your hard drive I don't know how this will work for you I have only done three PDF files. There are several apps that are designed just for PDF files you may find more useful for your needs just search the app store under PDF.
    10298
    Jul 2010
    Uk
    374
    Dropbox.
    15463
    Sep 2010
    Chicago, Il
    38
    Quote Originally Posted by Prasius View Post
    Dropbox.
    Stupid question. Not a computer person but trying. Is drop box a program? Can it be used with documents to go? Sorry if this is a really dumb question trying to learn.
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    Dropbox is website/computer app that saves your files and syncs changes etc you install on both pc and iPad then drag your folders to the drop box folder on pc. When you open drop box on iPad your files are there for you to use.
    10298
    Jul 2010
    Uk
    374
    What Brenn has said. I didn't continue to expand in that post as there is quite a lengthy thread on here full of dropbox love and tips just a couple of pages down.
    12225
    Aug 2010
    Denver
    387
    I love Dropbox, but there is one big caveat: All of your files are saved to their web servers. If you have Gigabytes of data this can take a long time, it can eat up your bandwidth caps, and it can cost money as Dropbox is free unless you need more than 2GB.
    Posted from my iPad WiFi 64GB
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    Thats true, but once you've transfered them you can download/save and delete too. Just be sure you save a copy on each computer (outside the dropbox folder) and you're good to start over if you're purpose is for file transfer.
  1. Replies: 2
    Last Post: 09-03-2010, 01:27 PM
  2. Folders within folders for photos
    By tdickerson21 in forum iPad Help
    Last Post: 08-08-2010, 10:17 AM
  3. iPad - Tunes in your car
    By AbsoluteMayheM in forum iPad General Discussions
    Last Post: 07-09-2010, 02:22 PM
  4. First synchronise to I-Tunes.
    By Northernstar002 in forum iPad Help
    Last Post: 06-30-2010, 12:51 PM
  5. How to port or make an iPad website or web app
    By combs1945 in forum iPad FAQ
    Last Post: 06-29-2010, 08:59 PM
add folders full of pdf's to ipad
copying pdf folder to i tunes
create ibook folder on pc
create pdf folders in itunes
creating folders in docs to go
how to add folder of pdf to ipad
how to create folders for pdf documents ipad
how to get create pdf folders on my ipad
how to get ibook folder in itunes
how to port pdf files to ipad
how to port pdf to ipad
itunes add pdfs folders
