I need to know if the Apple camera connection kit can be used with a usb midi controller keyboard with apps such as GarageBand. I have an iPad 3 with iOS 6.01
Hard to say without trying it, but I would not count on it.
Not on a stock non jailbroken iPad. I don't know if it would work on a jailbroken iPad.Originally Posted by SonicBodhi
The only thing the CCK will allow you to use it for is to see Photos and videos taken 'directly' from a camera or video recorder.
You can't even copy photos onto an sd card or USB stick..... they simply will not show.
Asking the CCK to do anything other simply won't happen ~ If I were you I would find out further info on Jailbreaking.
EDITED:
Okay, found a way to copy photos from a Laptop to the iPad using the CCK:-
1. Rename any photos you have with an 8 digit filename ~ Home0001 or Famly001.
2. Copy to an sd card and insert into the CCK.
3. Insert CCK into the base of the iPad and load the Photos App. This will then read the contents of any photos you have added using the 8 digit method.
.........I don't always get your questions right.... but you'll certainly know I've tried.
That's great information, but does not pertain to the question I asked, and aside from that, I don't need to jail-break my iPad, I can send photos to myself via e-mail and save them to the camera roll if I have to. This is about music, not photos.
I've done a little more research and found that there is third party hardware that will work with the cck at least on a guitar input. But I'm looking for a way to make my usb midi keyboard work with my iPad, so I don't have to buy a piece of hardware that requires me to use the antiquated midi dyn plugs.
Any suggestions, anyone?
I was looking for similar info about plugging in a USB microscope. Further research suggests that the CCK only recognizes mass storage, not webcams or input devices, and anything that works must convince the iPad it's a mass storage device. If a device doesn't specifically claim it works directly into an iPad, it probably won't.
Wrong. I bought a camera connection kit and plugged an Oxygen 25 midi keyboard in, and it uses the native OS 10 midi driver to run the keyboard in apps such as Garage Band, Sunrizer Synth, and DXi. My iPad 3 remains un-jailbroken. It is true that I get a message from the OS that says the device is not supported, but it works anyway.
Also a Logitech wireless keyboard with unifying receiver works well. Ignore apple message regarding unsupported device.
I have the ipad 4 and a bus powered midi keyboard that I cannot make work. The ipad says not sufficient power. Any help?
