The Room - Need help with Q - shaped panel
This is a discussion on The Room - Need help with Q - shaped panel within the iPad Games forums, part of the iPad App Store category; Never mind. I figured it out....
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 40
    245487
    Sep 2012
    Attached Thumbnails Attached Thumbnails The Room - Need help with Q - shaped panel-image-2185530182.jpg   The Room - Need help with Q - shaped panel-image-2081690456.jpg
    245487
    Sep 2012
    You turn the ring so that the grey opening is at 3 o'clock then slide the "bolt" to the right. You keep it and slide the bolt that's already at 5 o'clock down. There you can deposit the first one you picked up. Then turn the opening to 9 o'clock, slide the second bolt to the left and it should open. The term "bolt" is what threw me off.
    Fun game!!! Unfortunately, there's only one more chapter before the game ends
    245945
    Sep 2012
    Durham, NC
    Question The Room- stuck at the timer buttons
    Hello-
    Can anyone offer some help? I was doing well until I hit the part where you activate the light inside the box with the glowing crystal, then I got the little telescope on top to pop up, and there is a panel with two buttons that activate a timer located below the light on the top of the box. The last hint said to push a sequence of buttons before the timer runs out, but which buttons? Where? The star buttons that light up don't seem to be connected to the timer, and I don't immediately see any other buttons aside from the two with the timer. Please help! Thank you very much!
    245961
    Sep 2012
    UK
    Touch the left hand button, then zoom out and spin round the top of the unit.
    A series of boxes open up and you need to hit each button to restart the timer, after about three restarts you'll find the next object. Hope that makes sense
    245989
    Sep 2012
    London
    I have same problem! Flying until that point -
    Quote Originally Posted by Lifeonerth View Post
    Hello-
    Is it anything to do with the 16 star lights?
    Any help much appreciated...
    246014
    Sep 2012
    Ok, I can slide the bolt to the right at 3 o clock, but I don't understand "keep it". I can't pick it up, I can't rotate the ring, I can't figure this out? Help, please.
    246017
    Sep 2012
    Quote Originally Posted by Undermanager
    I am exactly at the same place ... Arg!! I think I moved the big bolt there and it's now too big to rotate? IDK...
    246014
    Sep 2012
    Quote Originally Posted by zonie77 View Post
    Ha, done it! Turn the wheel to 9 '0' clock first, slide the centre thingy into the ring, rotate the ring and put it in the space at 5 o oclock, then do the 3 o clock one! The above poster can't tell the time!
    246017
    Sep 2012
    Hmm. Apparently on my first attempt I did this goofy. I went 9:00 got the big bolt to 3:00 and now am stuck. Yah I know I did it wrong...now! Can't turn anything. Tried to turn it back, tried to get it to 5 ...get this...redid all of chapter two hopefully to refresh this stupid Q thing. Freeking crazy. Thanks tho..a lot.
    246016
    Sep 2012
    Still stuck at same place, earlier hint does nothing for me, any other ideas?
  1. Replies: 18
    Last Post: 08-10-2012, 11:26 AM
  2. ELECOM Faucet Shaped Stand for The new iPad
    By eKindom in forum iPad General Discussions
    Last Post: 05-25-2012, 04:32 AM
  3. Chat room
    By davidjg92 in forum iPad 1 Forum
    Last Post: 02-21-2012, 04:24 AM
  4. Any room for a little one
    By KATZ49 in forum New Member Introductions - Site Assistance
    Last Post: 06-24-2011, 04:44 AM
  5. Control panel
    By meric925 in forum iPad OS
    Last Post: 01-13-2011, 01:28 PM
the room app help
the room clock time
the room game q shaped panel
the room game time on clock
the room ipad game
the room q
the room q panel
the room q shaped panel
the room q shaped panel help
the room sequence of buttons with timers
the room steel tube
the room timer buttons
