Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 40 of 40
  1. #31
    5492
    May 2010
    El Paso, TX
    28
    and use the eyepiece
  3. #32
    246994
    Sep 2012
    the metal tube, you have to unscrew the top, then you will see a picture is being stuff in it, pull that picture out and then turn it over
  4. #33
    246670
    Sep 2012
    5
    Ok! I`v cracked the safe but forgot to bring whith me cog in to det next challenge. Now I dont know how to get back and get it!
    Anyone!!???
  5. #34
    246670
    Sep 2012
    5
    Thanx for U`r help, by the way!!
  6. #35
    248643
    Oct 2012
    Virginia
    The top of the tube comes off... there is something inside it.
  7. #36
    248643
    Oct 2012
    Virginia
    I am completely stuck on Chapter 2 and the Q shaped panel. I have aligned everything and moved the "doors" but nothing happens. Any suggestions? Frustrating!
  8. #37
    248741
    Oct 2012
    Tennessee
    Stuck here as well. Was doing great up until this point. I've tried all the starred buttons on the green keypad. Was able to push all of them before timer stopped. Nothing.
  9. #38
    269795
    Dec 2012
    Stuck in The Room
    Hello,
    I'm playing The Room and I'm stuck in the Orrerary (the level with the planets and planetarium). I've made it to the upper platform; I've decoded two patterns for the little twelve key keypad, but now the clues are indicating a third pattern and telling me I can see it through the panel when I have the eyepiece on. Well I can't. I had paused the game earlier, right after getting the gold medallion, and when I restarted it I think it got ahead of itself and now the clues are out of sync with my position in the game. If that's even possible. Anyway, I can't move forward. Can anybody help? Thanks, Kevin H.
    Th
    Anyway something seems off
  10. #39
    48665
    508 times
    Brisbane, Australia
    19,666
    Quote Originally Posted by kjhart0133 View Post
    Hello,
    Th
    Hi and welcome to the Forum!
    I've moved your post to this thread.....as these members are playing this game, you will get more help here. Enjoy!
    iPad 2 64gb 3G
  11. #40
    48665
    508 times
    Brisbane, Australia
    19,666
    Hello,
    Th
    I've played this game and from what I remember there are a few patterns. There was the pattern with 3 dots from each diagonal. Then 3 up from the bottom in the middle and 2 down from the top either side of the 3.....the next one if I remember correctly is that you will see a box structure through the wood panel, you need to turn the dial where that gold disk went to turn the box to reveal holes in it. You turn the box to match those arrows you can see on the flat top. If I remember correctly from the top it was the middle button, next line the 2 outside buttons, 3rd line was middle button again and line closest to you was the 2 outside buttons. Hope this helps.....there's another diagram one after that too. But you need to stop the planets moving to be able to do it....can't remember how I did that but they do give you a clue.
    iPad 2 64gb 3G
  1. Replies: 18
    Last Post: 08-10-2012, 11:26 AM
  2. ELECOM Faucet Shaped Stand for The new iPad
    By eKindom in forum iPad General Discussions
    Last Post: 05-25-2012, 04:32 AM
  3. Chat room
    By davidjg92 in forum iPad 1 Forum
    Last Post: 02-21-2012, 04:24 AM
  4. Any room for a little one
    By KATZ49 in forum New Member Introductions - Site Assistance
    Last Post: 06-24-2011, 04:44 AM
  5. Control panel
    By meric925 in forum iPad OS
    Last Post: 01-13-2011, 01:28 PM
the room app help
the room clock time
the room game q shaped panel
the room game time on clock
the room game what time to set the clock
the room ipad game
the room q
the room q panel
the room q shaped panel
the room q shaped panel help
the room time on the clock
the room what time to set the clock
