Why when i play game sound suddenly gone just like that.at the star game hve sound.but another 5 n further minute souns gone oyt.why?
This is a discussion on Sound problem within the iPad Games forums, part of the iPad App Store category; Why when i play game sound suddenly gone just like that.at the star game hve sound.but another 5 n further minute souns gone oyt.why?...
