Help with a rip from DVD to iPad compatible format
This is a discussion on Help with a rip from DVD to iPad compatible format within the iPad FAQ forums, part of the Apple iPad Discussions category; Originally Posted by Kinch Originally Posted by PhilipJFry I got ti figured out! Star Wars has never looked better than on the screen of the ...
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
  1. #11
    5958
    Jun 2010
    Columbus, Ohio
    23
    Quote Originally Posted by Kinch View Post
    Quote Originally Posted by PhilipJFry View Post
    I got ti figured out! Star Wars has never looked better than on the screen of the iPad.
    Well done Philip. Can you detail what you did so the next person with a similar query will learn what to do?
    Philip,
    I am in the same boat that you were starting out. I also use a PC and have no idea of where to even start with the dvd ripping process. I am an avid woodworker and have several instructionional project dvd's that I would like to rip/convert and view on my iPad(64g-wifi) during trips or even during lunch at work. Anything that you can share would be GREATLY appreiciated.
    Thanks in advance,
    Grant
  3. #12
    7488
    Jun 2010
    189
    For Windows, the easiest solution is to buy AnyDVD. This is essentially a driver that decrypts DVDs on the fly. Then you can use any DVD ripping/remastering software you want, because the the DVD appears to not be encrypted. In the case of Handbrake, you can go direct from DVD to MP4 in one step.
  4. #13
    7035
    Jun 2010
    Ireland
    6
    Quote Originally Posted by kierandill View Post
    Thanks Kieran and zaraly.Enjoy your iPads
  5. #14
    8202
    Jun 2010
    rip dvd to ipad
  6. #15
    3632
    May 2010
    Land O Lakes, FL
    28
    OK, I'm on PC. And whereas I'd LOVE to have a free program to rip and convert DVD's to something iPad friendly, I'm also not adverse to paying for something that will actually work. And I'm not talking about a program that requires a PhD in technology to decipher: I want something simple and one step, i.e., open the program, pop in a disc, tell the program to convert it, walk away and come back to a completed project that actually works with no further hassle.
    Does such a thing exist?
  7. #16
    iPad Enthusiast!
    7649
    Jun 2010
    Milwaukee, WI
    33
    Morning Lee,
    I'm in the same boat as many on this thread. Never had a need to rip any DVD's until the iPad waltzed into my life.
    Last night I purchased Winx DVD Platinum (29.95), that will take a DVD (encrypted or not) and take it right to mp4. Seems to me that it's a one stop shop. One click to mp4 solution.
    Now, I ran my first movie last night. So, I haven't been able to move it to iPad yet. However, I can't figure out why it won't work.
    We'll see, but you might want to look into Winx DVD. They have a free version, but if you have any copyright protected media, it won't rip those, you have to purchase the upgrade.
    Hope this helps...
    Cheers,
    M
  8. #17
    7954
    Jun 2010
    11
    Quote Originally Posted by LeeB View Post
    I can tell you the answer is yes. My recommendation to you is that after checking the tech forum and my own experience tells the most easy and stable converter would be Cucusoft dvd to ipad converter, it is not free converter like handbrake, however it does't required high degree of converter knowleadge and IT skills (I heard that even some IT geeks with phd degree having hassles with hanbrake) so by chipping some bucks, less than 30 bucks, you can have mind rested and get things done well, ie, your money will be paid off. TO get a cucusoft DVD to iPad Converter for window: DVD to iPad Converter - - iPad Converter, for mac version: DVD to iPad Converter for Mac - - iPad Converter
  9. #18
    3632
    May 2010
    Land O Lakes, FL
    28
    Thank you for your suggestions, Gentlemen. I got antsy and purchased a copy of 123CopyDVD Gold ... after all, the box said it would do everything I needed . I just got the opportunity to try it. After several hours of pre-processing and then converting, it flashed a screen that said the conversion was successful (I thought I'd try Apple TV vs. iPod) -- but I'll be darned if I know where it went! It never gave me the option of where to save the file, and I did a "search" and can't find it.
    Like I said, I don't mind paying $$$ for something that works, but I'm getting tired of spending the money on stuff that *doesn't* work.
    Are you happy with what you purchased?
  10. #19
    7954
    Jun 2010
    11
    Totally agree with what you said, mate! money can save lots of time sometimes, however, you should buy the right software instead...
    So far, my experience with DVD to iPad Converter - - iPad Converter is very good, no hussle at all and I can't be more happy with it.
  11. #20
    3632
    May 2010
    Land O Lakes, FL
    28
    Quote Originally Posted by ipadfans View Post
    OK, last night I purchased the program ... "assuming" that if it was for iPad alone, that it would be what I needed with no problems. The registration key was a bit late in arriving, but that's OK: it got here. Then I tried to copy Avatar. It worked, but it brought it down in 3 installments, not one continuous movie. And that's not acceptable. I haven't had the opportunity to check their website yet to see what happened, but if you have any suggestions ... ?
    I finally figured out the 123CopyDVD ... it works, but if I use the settings for Apple TV, it won't copy to the iPad (iTunes says it's not the right kind of file), and if I use settings for iTouch, it pixilates badly (difference in screen size?)
    I had high hopes for a converter that was iPad specific, but not if it splits the movie.
  1. Cydia packages/apps compatible for iPad!
    By trnjackie23 in forum iPad Hacking
    Last Post: 04-14-2011, 01:20 PM
  2. Ipad and non DRM epub format books
    By jrw in forum iPad Apps
    Last Post: 04-07-2011, 03:13 AM
  3. List of iPad compatible accessories
    By Robotguy in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-14-2010, 04:32 PM
  4. iPad photo format
    By thehatguy in forum iPad General Discussions
    Last Post: 05-28-2010, 11:06 AM
  5. Converting PDF book into IPad format
    By Raberdash in forum New Member Introductions - Site Assistance
    Last Post: 05-22-2010, 02:22 PM
convert dvd to ipad nero
how do i copy a dvd onto my ipad 2
how do i record a dvd to my ipad
how do i rip a dvd to my ipad
how to burn a dvd to ipad
how to dvd to ipad nero
rip dvd ipad
what format to burn dvd for ipad
