Drain and Then Re-Charge Battery?
This is a discussion on Drain and Then Re-Charge Battery? within the iPad FAQ forums, part of the Apple iPad Discussions category; Is it true that once a month you should completely run down the iPad battery and then fully re-charge it? Thanks so much....
Results 1 to 7 of 7
    82486
    Jul 2011
    mtrplato@gmail.com
    Thanks so much.
  2. #2
    96 times
    15,270
    Here is Apple's battery advice...
    Apple - Batteries - iPad
  3. #3
    iPad Ninja
    5787
    10 times
    Jun 2010
    2,255
    Your making me feel bad Tim.
    Did it the first month with the iPad1 when I bought it and never done it since on any of our pads. Haven't noticed any weakening of the batteries so far.
    Since I'll be upgrading whenever the next version is released it hopefully shouldn't matter........fingers crossed......
  4. #4
    96 times
    15,270
    To be honest, I've never done it either. What's that saying - "The cobbler's children are the worst shod" - that's me, a lifetime in electronics and computing and my house wiring would get me drummed out of the IEE and IEEE. But I guess we could say we know what the dangers are...
  5. #5
    iPad Ninja
    5787
    10 times
    Jun 2010
    2,255
    Lol consenting adults.
    Btw your photo looks as if you've lost weight since the previous one.....
  6. #6
    iPad Enthusiast!
    74786
    Jul 2011
    30
    All rechargeable batteries need to be cycled. If you keep them plugged in, the battery wont last as long. Like the link states its good to let the battery almost dry and recharging once a month, if it doesn't happen already, for the battery to work properly. You don't have to let it die completely just enough for it to reach a low percentage.
    Its completely normal.
  7. #7
    iPF Elite
    176 times
    Dayton, WA
    9,227
    Apples recommendation has nothing to do with preserving the battery's life expectancy. It only helps the iPad calibrate the battery's remaining charge percentage calculation.
    Given the nature of the newest generation lithium-ion batteries, and the expected usable life of mobile devices, worrying about when and how much to charge the battery is not worth the headache.
    Barring outright battery failures (which do happen), your iPad will most likely still have 80% of it's battery capacity (or more) after two years of use. And that's if you use it a lot, like almost a full discharge every day.
Sponsors
  1. Battery drain?
    By Tokkie in forum iPad Hacking
    Last Post: 07-11-2011, 11:56 AM
  2. Battery drain is it Safari?
    By Archer in forum iPad General Discussions
    Last Post: 06-19-2011, 01:03 PM
  3. tweaks that cause battery drain
    By beatlejohn in forum iPad Hacking
    Last Post: 02-18-2011, 10:20 AM
  4. Battery Drain??.
    By David Vice in forum iPad FAQ
    Last Post: 02-06-2011, 03:05 AM
  5. How to drain battery
    By Kim in forum iPad Help
    Last Post: 10-29-2010, 05:23 PM
apple recharge battery forum
battery failure
do i have to drain ipad battery the first time
drain ipad battery to what percent
how do you fully discharge an ipad battery
how much is completely discharged ipad battery
how to discharge ipad battery
how to run down i-pad battery
how to run down ipad battery
ipad battery complete discharge
is it better to fully charge ipad or 80%
recharging battery
run down an ipad battery
shoul you drain ipad 2 battery befire recharging
should i drain the ipad battery before recharging
should one run down an ipad battery
should you drain ipad battery
should you drain your ipad battery the first time you use it
should you run an ipad battery down
what percentage should you charger your ipad for the first time
