iPad golf pushcart mount with solar powered fan
This is a discussion on iPad golf pushcart mount with solar powered fan within the iPad DIY forums, part of the Apple iPad Discussions category; I use Golfshot GPS on my 64gb 3g ipad, and wanted something that would allow me to attach the iPad to my pushcart.
I started ...
I started with a simple stand made of three sided boxed aluminum that you can get at Home Depot in the door section, cut it with a small cordless hacksaw. The hacksaw with miter box does a shoddy job on angles so version 1 looks rough around the edges. I used copper pipe and rivets for all connections. I also used some aluminum flat stock to attach my pieces together.
MobileMe Gallery
The iPad overheated after about 10 holes and needed to be shut down and cooled for a while. I believe direct sunlight was the culprit.
I headed back to the drawing board and came up with Version 2. This one is made of one piece of boxed aluminum c channel, folded at the corners to minimize rivets bracing. This time I used my 12" Milwaukee miter saw with a non-ferrous metal blade.
MobileMe Gallery
I attached a Volkswagen solar charger to a small computer fan sucking the hot air from the back of the iPad.
I have not been able to hit the links yet, but should get out there soon and I will report back on my experiences.
07-08-2010 10:03 PM
iPad Enthusiast!
Nice! I love the solar powered fan!
iPad Ninja
Great work.
Your main problem is that you will now need a powered golf cart.........
This could be the start of a business empire!
thanks for the comments. I wish I knew how to weld so I could really go to town on this and eliminate things like the copper and rivets. hehe
Updated it with the Ram-Mount system for the ipad. Looks less chopped up and more elegant IMO.
MobileMe Gallery
Solar Powered Fan
Great idea! Thanks for sharing
- You may not post replies
- You may not edit your posts
Forum Rules
By dbdoug in forum iPad Accessories
Last Post: 05-20-2012, 05:18 PM
By Rick Ornberg in forum iPad Accessories
Last Post: 04-17-2011, 07:57 PM
By zman in forum iPad Games
Last Post: 06-23-2010, 06:16 AM
By Appleaddict in forum iPad Help
Last Post: 06-22-2010, 04:23 PM
By jaycidy in forum iPad General Discussions
Last Post: 05-12-2010, 11:33 AM
clamp on ipad holder for golf cart
golf cart ipad holder
golf ipad accessories
golf ipad mount
golf push cart ipad
golfshot and new ipad
golfshot for ipad
golfshot for ipad?
golfshot ipad
golfshot on ipad
ipad 3 golf bracket
ipad accessories for golf
ipad golf accessories
ipad golf cart mount
ipad golf mount
ipad holder golf
ipad stand for golf
ipad stand golf
solar fan for golf buggy
solar golf cart fan
