Hey everyone here is my homemade waterproof iPad case
It was very scary testing it out
[ame=http://www.youtube.com/user/ZooGueBROKEtoRICH#p/a/u/0/xIAp9F2A9sI]YouTube - ZooGueBROKEtoRICH's Channel[/ame]
Enjoy
Tim Angel
This is a discussion on Home Made case -- iPad Under Water within the iPad DIY forums, part of the Apple iPad Discussions category; Hey everyone here is my homemade waterproof iPad case It was very scary testing it out [ame=http://www.youtube.com/user/ZooGueBROKEtoRICH#p/a/u/0/xIAp9F2A9sI]YouTube - ZooGueBROKEtoRICH's Channel[/ame] Enjoy Thanks Tim Angel...
Enjoy
Tim Angel
People have been doing this for quite a while with ebook readers...
Not white, not black just passionate shades of grey...
Yuno Wataï Minh
Moved to the DIY forum.
64GB Wifi iPad Owner
Minute of glory![]()
Just remember: there are zip lock bags, and then there are ZIP lock bags. The ones with the slide lock could leak ... the single line zip is pretty secure, but they make freezer bags that have 2 zip lines. The bag is a little thicker, but it's much more secure.
Once upon a time, I used to go canoeing ... I found that zip lock bags are your friend! They come in all sizes, and will help keep things dry. I wouldn't want to try diving with it, but for keeping splashes and sudden (shallow water) submersions from damaging electronics, there's nothing better than zip lock bags. Great for sitting pool-side, too. Or getting caught in the rain.
One other thing: if you're just trying to avoid "splash", squeeze the air out of the bag before it's "locked" all the way and it makes it easier to handle. If you're out in water and think you may drop it (or capsize!), LEAVE air in the bag: it will help make it more buoyant and float to the surface so you can find it.
Thanks for posting your idea. It's one of those forehead slapping "Duh! Why didn't *I* think of that?" tips.
Great job Niel Armstrong! You nearly sacraficed your iPad life for the betterment of others!- LOL Thanks for doing so, now we know the outcome. Appreciate it my friend.
iPhotograph...<APRIL 3RD OWNER> Big Karma & Be Ez
That saves me from spending the $25 I was going to spend on a Trendydigital waterproof bag I was about to buy!
Would you really trust a ziplock bag for more than just a youtube video?
A good waterproof solution would be one that is vacuum sealed and also has a melted seal that you peel off and toss when your done...that way it would be waterproof and would still keep its form factor. Like a shrink wrap.
