Custom Made Acrylic Car Mount
This is a discussion on Custom Made Acrylic Car Mount within the iPad DIY forums, part of the Apple iPad Discussions category; Hey all, I thought I would post the pics of my car mount now that it is finally done. The vehicle it is in is ...
Results 1 to 10 of 12
    13582
    2 times
    Aug 2010
    Indiana
    305
    Hey all, I thought I would post the pics of my car mount now that it is finally done. The vehicle it is in is a 2004 Sebring convertible. As you can see I relocated my Kenwood head unit down into where the factory 6 disc changer was...this only required enlarging the opening in the panel just a bit and did not require me to lengthen an wires. Now, the actual mount...a 1/2 inch thick piece of laser cut acrylic (main base) with the two brackets being 1/4" thick by 3/4 wide. The main base as well as the inside of the holding brackets are covered in adhesive backed hobby foam. What I did to mount it to the dash was to take the mounting kit that had been used with my head unit and on the inside of it I screwed in a piece of solid oak and painted it black as well as drilled a hole through for running the charge/audio cable. Then, onto the from of the mounting kit i screwed a 2x4 from the back onto it. This piece is a straight cut for the end that is attached to the stereo mount and the end that is attatched to the iPad holder is cut at a 60 degree angle. The holder is screwed into this then the adhesive backed foam covers the screws so they are never seen. Also the length of the 2x4 is 4" at the longest point, this puts it in perfect reach while driving and it is absolutely solid...does not bounce around at all! Also, the foam keeps it from moving as it isnt a tight squeeze to slide it in as i didnt want my screen marred up. If anyone would like one of these to be made, get in contact with me and we can work something out...obviously, relocating a head unit isnt an option in every vehicle where your sound components end up is on you. If you're in the central Indiana area a complete install done by me is an option. Suggestions and comments are always welcome!
    Attached Thumbnails Attached Thumbnails Custom Made Acrylic Car Mount-hpim0502.jpg   Custom Made Acrylic Car Mount-hpim0503.jpg   Custom Made Acrylic Car Mount-hpim0504.jpg   Custom Made Acrylic Car Mount-hpim0505.jpg
    There is only one Return, and it's not Of The King, it is Of The Jedi.
  2. #2
    16596
    Oct 2010
    The Centre of The Universe, UK
    32
    Great!
    I like to see wood being used for making 21st Century tech fit in with our lives.
  3. #3
    iPad Enthusiast!
    11582
    Aug 2010
    34
    zoooo muchhhh glarrrezzzzz
  4. #4
    14271
    Sep 2010
    SC
    5
    Nice job.. looks great. I thought of doing something like that too.
  5. #5
    3636
    May 2010
    Redding, CA
    162
    You probably need one of the anti glare screen protectors. It might help.
    Mary iPad 1 64G 3G owner
    PJ iPad 1 64G 3G owner
  6. #6
    iPad Junkie!
    14026
    Sep 2010
    Staffordshire
    126
    Looks great! Like the real wood idea!
    iPhone 32GB 3GS & iPad 32GB 3G - a matching pair!
  7. #7
    13582
    2 times
    Aug 2010
    Indiana
    305
    Actually, the glare in sunlight with the top down is not all that bad. I haven't gone with using an anti-glare protector because of the iridescent prism effect all that I've seen so far seem to have. Going to be getting an otterbox defender case soon and am going to have to modify the mount to hold it.
    Already done something I've wanted to do for a long time....go through a drive through with a car full of people with the top down, playing a porn on the screen, but acting totally oblivious to it and have someone in the back film the reaction. lol Maybe a bit immature, but it makes for great laughs! lol
  8. #8
    20529
    Nov 2010
    6
    love it, i want to work on something like this as well
  9. #9
    21955
    Nov 2010
    Michigan
    5
    I need this badly
  10. #10
    13582
    2 times
    Aug 2010
    Indiana
    305
    Hey all, did an update on this. I finally got my Otterbox Defender case and have modified the mount. Basically I totally done away with the acrylic base and L-brackets and am now just using the snap on cover/stand of the defender screwed directly into the dash mount. Snaps in and out easily, yet no ammount of jarring or rough roads/rr tracks will make it come loose.
    Attached Thumbnails Attached Thumbnails Custom Made Acrylic Car Mount-hpim0532.jpg   Custom Made Acrylic Car Mount-hpim0536.jpg
Sponsors
  1. Custom wooden iPad stand made.......
    By DoingOK in forum iPad Accessories
    Last Post: 05-16-2011, 02:28 AM
  2. New Acrylic Ipad Stand
    By littlebuddha in forum iPad DIY
    Last Post: 12-29-2010, 11:40 PM
  3. My new, custom-made, eco-friendly iPad case!!!
    By iDharma in forum iPad Accessories
    Last Post: 07-09-2010, 04:27 PM
  4. What is the best acrylic case for the iPad?
    By tom1252 in forum iPad General Discussions
    Last Post: 07-06-2010, 02:56 PM
  5. Custom made iPad carmounts
    By Ripplinghurst in forum iPad Accessories
    Last Post: 05-29-2010, 12:45 PM
custom dash kits for ipad
custom dash mounted ipad
custom ipad car mount
custom ipad car mounts
custom ipad dash mount
custom ipad mount for car
custom ipad mounts
custom ipad vehicle mount
custom snap-on
customized ipad auto mounts
defender dash
diy ipad car mount
install ipad in car dash
ipad car mount custom
ipad custom car mount
ipad custom dash mount
ipad dash mount
no stereo custom automotive dash
plexiglass ipad mount
plexiglass ipad stand
