Recommendation for a quality DIY IPAD 3 cracked-screen repair-kit?
This is a discussion on Recommendation for a quality DIY IPAD 3 cracked-screen repair-kit? within the iPad DIY forums, part of the Apple iPad Discussions category; My main concern here is finding a seller who sells repair kits with IPAD-comparable-quality screens? Also, how hard is this to do at home? Is ...
Results 1 to 4 of 4
    230573
    Jul 2012
    New Yawk City
    41
    Also, how hard is this to do at home? Is it worth the savings or should I just go swap it out at an Apple store (which I thing runs about $300)?
    48665
    952 times
    Brisbane, Australia
    23,510
    Quote Originally Posted by kwitel View Post
    My main concern here is finding a seller who sells repair kits with IPAD-comparable-quality screens? Also, how hard is this to do at home? Is it worth the savings or should I just go swap it out at an Apple store (which I thing runs about $300)?
    We recommend taking your iPad to an Apple Store where hopefully (they mostly always do) they will replace your iPad with a new one. The price of this is normally half of what you have paid for it.
    Yes there are cheaper routes of accomplishing this but we have had many go the cheaper route of going to a repair shop or attempting it themselves only to realise that something else has been damaged in the process. (Wifi cable is broken, areas of the screen that will not work, home button damage). There may also be other damage within your iPad that you may not be aware of as yet (I assume that the broken screen was caused by a drop)
    If you do elect to go to Apple, make an appointment with the Genius Bar first and do a complete backup of your iPad, receipts are not needed as they can look up all relevant info instore.
    Good luck!
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
    230573
    Jul 2012
    New Yawk City
    41
    Quote Originally Posted by leelai View Post
    Good luck!
    Thanks Leelai.
    What if I originally bought the Ipad at Best Buy and not at Apple?
    Will they still swap it out?
    48665
    952 times
    Brisbane, Australia
    23,510
    Thanks Leelai. What if I originally bought the Ipad at Best Buy and not at Apple? Will they still swap it out?
    You're welcome!
    It makes no difference......I've bought Apple gear from resellers at times and have had no problem taking them back to an Apple Store.
    Good luck!
  1. Ipad screen repair
    By earlboston in forum iPad 2 Forum
    Last Post: 11-15-2013, 09:00 AM
  2. iPad 2 broken screen Apple or local repair firm?
    By jonkers in forum iPad 2 Forum
    Last Post: 08-24-2012, 06:15 AM
  3. Replies: 8
    Last Post: 05-02-2012, 10:24 PM
  4. iPad broken screen (cracked screen)
    By stephens2923 in forum New Member Introductions - Site Assistance
    Last Post: 12-04-2011, 08:51 PM
