Ajax HTTPS POST call does not work in iPad
This is a discussion on Ajax HTTPS POST call does not work in iPad within the iPad Development forums, part of the iPad App Store category; Hi, We are developing a mobile app to be ported to the Android and IPAD platforms. The idea is to use the same code and ...
Results 1 to 1 of 1
    89583
    Aug 2011
    India
    Hi,
    We are developing a mobile app to be ported to the Android and IPAD platforms. The idea is to use the same code and create APK and IPA files as deployable apps for Android and IPAD respectively using Phonegap build process.
    The app makes an Async xmlHttpRequest call to a REST based HTTPS URL using POST Method. The response is in JSON format.
    The call works well from the app deployed on the Android platform and gets back with proper response and HTTP status code(200). But, the same app call fails from the IPAD. It returns an xmlHttpRequest response status code 0. Looking at this, there does not seem to be an issue of Cross-Domain here since the call from the app from Android works well to the same URL.
    Any ideas as to what could be the problem with the call in IPAD?
    Here is the code snippet used:
    var xmlhttp = new XMLHttpRequest();
    xmlhttp.open('POST', url, true);
    xmlhttp.setRequestHeader("Content-Type","application/x-www-form-urlencoded");
    var myform = document.forms[0];
    var reqBody = getRequestBody(myform);
    xmlhttp.send(reqBody);
    xmlhttp.onreadystatechange = function() {
    // If state == 4, read the status code.
    Thanks a lot!
Sponsors
  1. How can use my sim in ipad to call and sms
    By Smksalmi in forum iPad 2 Forum
    Last Post: 05-05-2011, 04:51 PM
  2. Call the USA on iPad-For Free
    By chesterhound in forum International iPad Users
    Last Post: 04-25-2011, 01:22 PM
  3. HTTPS server is not responding error
    By dawgpound in forum iPad Help
    Last Post: 04-15-2011, 04:29 PM
  4. How to call from ipad using the gsm
    By Yogesh.dandawate in forum iPad Apps
    Last Post: 03-31-2011, 02:42 AM
  5. https sites
    By RAC in forum iPad General Discussions
    Last Post: 01-06-2011, 05:23 PM
$.ajax not working ipad
ajax does not work on ipad
ajax post not working on ipad
android phonegap ajax post soap ssl
does ajax work on ipad
http request.open not working on ipad
https call from an ipad
https ipad
ipad ajax not working
ipad ajax response
ipad app ajax not working
ipad http post
ipad https
ipad post form fails
ipad xmlhttppost
issues on ipad ajax with https
jquery ajax call in ipad
select ipad ajax
xmlhttprequest ipad
xmlhttprequest.open is not workin on ipad
Tags for this Thread
