ipad 2 wifi will "pair" but won't connect via bluetooth to Verizon/Motorola Razr
This is a discussion on ipad 2 wifi will "pair" but won't connect via bluetooth to Verizon/Motorola Razr within the iPAD Connect forums, part of the Apple iPad Discussions category; Hello; i'm a noob, so pls be kind. ;T) I have an ipad 2 wifi only model and I'm trying to connect it via Bluetooth ...
Results 1 to 2 of 2
    232368
    Jul 2012
    United States
    Cool ipad 2 wifi will "pair" but won't connect via bluetooth to Verizon/Motorola Razr
    I have an ipad 2 wifi only model and I'm trying to connect it via Bluetooth to my Motorola Razr android phone. My phone sees the ipad and says it's paired with it, and the ipad "sees"/recognizes the Droid Razr but it says it's "not connected". I've tried to have the ipad "forget" the device and start over; same result. I've tried to re-pair from the razr side and it pops up a dialog box with the pairing code on the ipad and it corresponds to the code that pops up on the razr, but despite that it still ends up "not connected" on the ipad.
    I'm trying to do this in order to use the GPS function on my phone and have it feed the GPS fix to my iSailor app on the ipad. Will this even work, if I get them Bluetooth connected??
    THANKS!!!
    Cal
    Grand Rapids, MI
    85546
    579 times
    Aug 2011
    Edmonton AB Canada
    9,852
    Probably not. Bluetooth connectivity on the iPad is limited. You can pair headphones, BT earpieces, iPhones ( for use with personal hotspot) and keyboards.
    I think what you are trying to achieve is beyond the scope of the iPad.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
  1. Replies: 2
    Last Post: 12-25-2011, 12:01 PM
  2. Motorola S10-HD Universal Bluetooth Stereo Headphone won't pair
    By ThePhotog in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-16-2011, 11:47 PM
  3. Replies: 15
    Last Post: 06-20-2011, 02:24 PM
  4. Replies: 3
    Last Post: 06-17-2011, 11:58 PM
  5. Replies: 12
    Last Post: 05-30-2011, 09:33 AM
anyway to pair droid razr m to ipad 2
bluetooth connect to android
connect ipad to motorola raz m
ipad does not connect with droid razr
ipad wifi 7.0.4 willl not pair with android
ipad2 android bluetooth pair
my ipad is paired with my vehicle but won't connect
pair ipad with droid razr
