Connect iPad to MBP as an external monitor, but need to use cable. NOT Air Display.
This is a discussion on Connect iPad to MBP as an external monitor, but need to use cable. NOT Air Display. within the iPAD Connect forums, part of the Apple iPad Discussions category; Hello all. Any ideas on how I can use an iPad as an external monitor NOT using AIR DISPLAY? It will be for pro use ...
Results 1 to 4 of 4
    304666
    Oct 2013
    Brooklyn
    Hello all. Any ideas on how I can use an iPad as an external monitor NOT using AIR DISPLAY? It will be for pro use so I don't trust wireless due to so much traffic, and while testing, there was some lag time using our program on the iPad even with fast router/internet.
    OR is there any way to setup an iPad to be used exclusively as a monitor. They are the perfect size for use on a stage setup, but can't find a solution involving cables.
    Thanks in advance.
    Dan WebRep
    currentVote
    noRating
    noWeight
    1546 times
    Walla Walla, WA
    15,468
    You can't. The iPad has no video-in capability in the connector. Something might be cobbled together via USB, but I've never heard of an app doing it. The developer would pretty much have to write their own USB/Video app for both ends.
    Air Display does not use the internet, only your home network. Fast as the router may be, the iPad's wireless radio probably can't take full advantage of it. The new iPads should do better, or so they keynote suggests. It might be necessary to upgrade the router, again, to get that performance, since it depends on the new ac standard.
    304666
    Oct 2013
    Brooklyn
    Thank you so much for replying. I'm bummed since I can't find any monitors even close to the size of an iPad I want to use for tele prompting on concert tour. There aren't any monitors I can find that are as slim. I don't feel confident using Air Display for such application of scrolling.
    Thanks again,
    Dan
    1546 times
    Walla Walla, WA
    15,468
    If all you want is tele prompting, and not an actual second screen, I believe there are several apps available. While a network may be too slow or unreliable for streaming a screen, tele prompting is nothing but text, which almost any network can handle with no noticeable delay.
    I can't offer any specific advice, since I don't use or need this application; but it would probably be worth your while to look into it.
  1. Replies: 1
    Last Post: 11-26-2012, 05:16 PM
  2. How to connect an iPad to a monitor?
    By healer in forum iPad General Discussions
    Last Post: 10-12-2012, 04:26 PM
  3. External Monitor for new Ipad
    By jay rogers in forum iPad Help
    Last Post: 04-18-2012, 03:55 AM
  4. connect iPad to monitor
    By Gternent in forum iPad Help
    Last Post: 02-02-2011, 06:39 AM
  5. How To Connect iPad to a HD TV/External Display
    By AppleiPadTV in forum iPad General Discussions
    Last Post: 08-12-2010, 07:30 AM
connect ipad as an external monitor
how to connect ipad air to via monitor
ipad as second monitor via cable
using an ipad as an external monitor
using ipad as monitor
