Using sim card from Sierra wireless air card in ipad
This is a discussion on Using sim card from Sierra wireless air card in ipad within the iPad Carriers forums, part of the Apple iPad Discussions category; I just purchased a 3G iPad. I have a Sierra wireless air card from AT&T that I use in my laptop with a 5gb per ...
Results 1 to 4 of 4
    13046
    Aug 2010
    Mobile, AL
    I just purchased a 3G iPad. I have a Sierra wireless air card from AT&T that I use in my laptop with a 5gb per month plan. I'd like to use the sim card from that device in my iPad. I purchased a sim card cutter and cut the card down. With the included adapter, the card still works fine in my air card on my laptop.
    If I put the sim card in my iPad, I show an AT&T 3G connection in the upper left corner of my screen. However, when I open safari I get a message saying that I have not signed up for a data plan and asking me if I would like to. If I say no, I get the following message:
    "The sim is currently active and not available for activation in this device"
    The APN is set to "broadband" which is the same setting my air card uses.
    Can I get this card to work in my iPad? It is my understanding that the iPad is unlocked... Obviously there is something I'm missing. I've done some searching to attempt to find a resolution, but all the threads I can find relate to getting an iPhone or other carrier's sim to work.
  2. #2
    13046
    Aug 2010
    Mobile, AL
    Fixed!
    Solved my problem. Found something about changing APN to wap.Cingular and that cured the problem. 3G is now working great!
  3. #3
    iPad Master!
    6869
    2 times
    Jun 2010
    California
    1,282
    Thanks for sharing the info I'm sure it will come in handy for someone soon!
  4. #4
    21328
    Nov 2010
    los angeles
    So do we have to do the BROADBAND change and the wap.cingular change?
Sponsors
  1. Non-3G iPad with AT&T 3G Air Card possible?
    By BuilderBob in forum iPad Accessories
    Last Post: 08-22-2010, 03:29 AM
  2. Got my Ipad(Sim card?)
    By skipper in forum iPad Help
    Last Post: 05-27-2010, 11:33 AM
  3. SD card wireless access..So cool
    By Edlex in forum iPad General Discussions
    Last Post: 04-06-2010, 10:41 AM
  4. iPad Card Trick
    By Dylan in forum iPad General Discussions
    Last Post: 04-03-2010, 02:39 PM
  5. Eye-Fi Wireless Mem Card
    By iDan in forum iPad General Discussions
    Last Post: 03-25-2010, 09:08 PM
air card for ipad
aircard sim use with ipad
can an air card be used on ipad
can i use aircard sim in ipad?
can i use an att air card with the new ipad
can i use my air card sim on my ipad 3g
can i use my aircard sim for the ipad
can i use my aircard sim in my ipad
can i use my att sierra sim card in my ipad 2
can i use my mobile broadband air card with my ipad?
can i use sim card in my air card for my ipad
can my air card's sim be used in an ipad
can you use sierra wireless aircard with ipad
can you use sprint sierra wireless with ipad
how to use sierra aircard for ipad
sierra wireless for ipad
use at&t aircard sim in ipad
use att air card sim in apple ipad 2
use att aircard sim in ipad
where is my sim card located on sierra wireless card
