Need a powerpoint with audio
This is a discussion on Need a powerpoint with audio within the iPad for Business and Education forums, part of the Apple iPad Discussions category; Hello all, Have been racking my brain trying to figure this out. I have a series of PowerPoints I want to make. Each one consists ...
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By paducah1983
Thread: Need a powerpoint with audio
    196305
    Apr 2012
    7
    Hello all,
    I have a series of PowerPoints I want to make. Each one consists of 7-100 slides and I want to be able to view them on my ipad.
    Thats the easy part. I have an audio file that needs to play in the background of each one. I cannot get it to work on my ipad. It plays fine on my PC but I get no audio on the ipad.
    I know that I can only embed a wav file into a powerpoint but for some reason when I download it from DropBox to my ipad or upload it to SlideShark the audio will not play.
    Any ideas? Is there a way I can make a Keynote presentation on my PC that will work?
    Thanks for any help. Been messing with this for 2 days now.
    32660
    3 times
    Feb 2011
    163
    Try the SlideShark Ap.
    Edited...just went back and looked at the specs...no audio, yet.
    196305
    Apr 2012
    7
    Yeah I've been trying to use it. I didn't realize that it said there was no audio support. I thought I was just doing something wrong.
    Thanks for the suggestion. Seems like such a simple thing. Just need to have a powerpoint with audio. How hard could that be? lol
    196305
    Apr 2012
    7
    Yeah I was thinking about changing it to a video. The problem is that the audio doesn't go perfectly with the slides. I would have to watch through it and set each one to change at a different time. If you could change the slides manually it would work better. Might not have any other options though.
    Thank you for taking the time to suggest it.
    14255
    16 times
    Sep 2010
    Berlin, Germany
    237
    I am not sure if I've understood your setting correctly.
    When you say you want to have the PPT with say 20 slides - do you want to have 1 audio file playing during all the 20 slides or 1 audio file for each slide?
    Both is possible.
    1. 1 audio file for 1 slide. - I use keynote app. I import the ppt without the audio files. (either through iTunes or WebDAV or Dropbox or...) Then I use "super" (freeware) on my PC and convert the audio files to a movie file with the following settings: Output Container: Apple iPad/iPod - Output video codex Divx - Output audio Codex AAC LC
    I get something like audio.mp3.mp4 which I can sync with iTunes and find on the iPad under photos.
    I open Keynote and add the corresponding audio.mp3.mp4 to the slide and set my animations or transitions. This is repeated for every slide.
    2. 1 audio file for the entire PPT: You use whatever presentation tool you prefer and start your audio file from the music app. When you are done with the presentation you stop the music.
    Hope this helps.
    Knut
    If you happen to be in Berlin, Germany, please let me invite you to a cup of tea, coffee or a pint of beer.
    208458
    May 2012
    Slideshark's sister app, mybrainshark will do it for you- for free even! lets you put audio on PPT and then you can view it from the ipad.... works great
    Kricke likes this.
    14255
    16 times
    Sep 2010
    Berlin, Germany
    237
    Thanks, I just downloaded it. Will give it a try.
    Knut
    212128
    Jun 2012
    10
    Try app "kingsoft office free".
    309636
    Jan 2014
    México
    Why don't you make your presentation on video and use the video instead of the PPT?
    212128
    Jun 2012
    10
    Installing an app (Kingsoft Office Free) is simpler than installing a converion program and learning how to use it (and pay for it).
    I get very good results with this application. It also enables you to present password protected PowerPoint files.
    Give it a try, it works as a miracle.
  1. Will Skyfire stream audio from flash audio player?
    By wahoowad in forum iPad General Discussions
    Last Post: 04-03-2011, 03:54 PM
apps used to play powerpoints with sound
can you listen to powerpoint on ipad
how to listen to powerpoint audio on ipad
how to watch pps files with audio sound in ipad
no sound powerepoint ipad
slide shark sound
slideshark audio
