Help with saving files using QuickOffice Pro HD
This is a discussion on Help with saving files using QuickOffice Pro HD within the iPad Apps forums, part of the iPad App Store category; Hi can some please explain to me how I can save documents using QuickOffice Pro HD to a network HDD that is connected to my ...
Results 1 to 2 of 2
    223682
    Jul 2012
    Hi can some please explain to me how I can save documents using QuickOffice Pro HD to a network HDD that is connected to my Airport Extreme wireless router.
    I also want to be able to access/open documents using QuickOffice Pro HD from the network HDD.
    iPad Addict
    168139
    83 times
    Feb 2012
    Brisbane, Australia
    1,319
    QuickOffice itself cannot access network drives, but does have solid cloud storage options like Dropbox and Evernote. The solution would be an intermediary app to facilitate the storage aspect, something like GoodReader.
    The idea would be to have said files on the network drive, have GoodReader set-up to connect to the network drive. Go to the location and pull the required file into GoodReader's My Documents. Once there, select the file and use Open In... to have the file open in Quickoffice.
    The hiccup would be getting the file from Quickoffice to the network drive. In fact, getting it back to GoodReader is difficult. At this stage, using Dropbox to get it to GoodReader is the only way I can think of to do it.
    In Quickoffice I drag the file to my Dropbox. I then open GoodReader and open my Dropbox folder. Select the file and download to GoodReader's My Documents. Once there, I select the file and click Upload and select the network share, navigate to the folder and click upload.
    It is a little messy, but works. You are leaving copies of the file in the Dropbox and GoodReader (plus Quckoffice) along the way.
    Hopefully QuickOffice will add access to network storage to a future update which will simplify the process emmensely.
    dhewson777
    Brisbane, Australia
    iPad 2 , iPhone 4, MBA 11"
    Yes, I have windows PCs as well! (too many to list)
  1. Saving web files
    By ronmoz in forum iPad Apps
    Last Post: 09-29-2011, 04:32 AM
  2. Saving music files from the web
    By radik76 in forum iPad Help
    Last Post: 07-09-2011, 01:03 PM
  3. Saving numbers files
    By tduffyiowa in forum iPad Help
    Last Post: 06-01-2011, 06:55 PM
  4. Dropbox: saving files on ipad
    By NJM in forum iPad Apps
    Last Post: 03-15-2011, 05:31 PM
  5. Saving files to ipad
    By shuttlegoose in forum iWork Forum
    Last Post: 01-20-2011, 10:22 PM
how to save a document in quickoffice
how to save a file in quickoffice
how to save in quickoffice
quick office pro ipad how to save?
quickofficehdpro helps
save documents quickofficeprohd
save documents with quick office pro
saving quickoffice documents
