Data transfer using physical USB drives with Camera connection kit
This is a discussion on Data transfer using physical USB drives with Camera connection kit within the iPad Apps forums, part of the iPad App Store category; Hi, am newbie here. Just got my iPAD2 and have start using it as a basic tool on my business trips. I have loaded up ...
Results 1 to 4 of 4
    170313
    Feb 2012
    Hi, am newbie here. Just got my iPAD2 and have start using it as a basic tool on my business trips. I have loaded up Office2HD but when my client share his Infor or files with his USB drive, I am unable to retrieve using Apple Camera Conversion Kit. Can anyone here help to enlighten me if there is anyway to retrieve or transfer data and files from any USB drive via camera connection kit into iPAD2 (without JB)?
    Thanks.
    161055
    Feb 2012
    Florida
    Using a USB drive is hit or miss. I have 15+ different drives, and out of all of them, one can be used with my iPad 2. The first thing need to do is connect the drive to your pc/Mac, and create a folder on the drive named DCMI. Once that is done, connect the drive to the iPad via camera connection kit. At that point you'll be able to tell if the drive will work. BTW, my iPad 2 is not jail broken.
    84371
    Aug 2011
    9
    What she said
    As I understand it , you will either need to jailbreak or follow the procedure described above (renaming the files to make them appear as if they are picture files).
    111086
    Oct 2011
    UK
    16
    I found the camera connection kit frustrating at fist as was trying to load a video but it wouldn't recognise it. However as others have said this is easily resolved by renaming the file to the same format as a photo ( from memory something like ABC12345). The only downside is you have to remember which file is which movie
  1. Replies: 1
    Last Post: 10-28-2011, 01:29 AM
  2. Camera Connection Kit and file transfer advice
    By Jon_C in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-13-2011, 06:02 AM
  3. Camera Connection Kit transfer to Removable Flash Disk
    By mattiebrownoz in forum iPad Hacking
    Last Post: 07-25-2011, 11:28 PM
  4. Camera Connection Kit transfer other files?
    By BlueBaka in forum iPad Help
    Last Post: 09-19-2010, 11:17 PM
  5. Replies: 3
apple camera connection kit transferring date us flash
camera connection kit onto usb drive
data connection kit
data transfer connection kit
how do you transfer information from a flash drive to an ipad
how to transfer doc file using camera connection kit
how to transfer documents using camera connection kit
ipad camera connection kit data files
ipad camera connection kit read usb drive
ipad camera kit move files to flash drive
usb data transfer to ipad 2
which apps can read from the camera connection kit
