Problem w/ Kensington Keyfolio Pro 2
This is a discussion on Problem w/ Kensington Keyfolio Pro 2 within the iPad Accessories forums, part of the Apple iPad Discussions category; I just got this case and I'm having this problem - Kensington - Tablet - iPad & iPad 2 - Cases Sleeves & Bands - ...
Results 1 to 7 of 7
    96896
    Sep 2011
    44
    Kensington - Tablet - iPad & iPad 2 - Cases Sleeves & Bands - KeyFolio
    The keyboard repeats letters. Like I'm holding them down. I try to backspace to stop it but backspace repeats. I try ton type on the iPad keypad but backspace is still repeating so i get one letter and it backspaces over it. I have to turn off the keyboard and then turn off Bluetooth on the iPad to stop it. Then a couple times the iPad keypad isn't visible and I can't get it to show so I have to turn back on the Bluetooth keyboard and hit the keyboard button to have it come back on
    I've posted on Kensington support site also.
    Anybody got any ideas??
  2. #2
    iPad Addict
    3736
    11 times
    May 2010
    Minnesota
    1,496
    Sounds like the device has a severe ghosting problem. I would try to get a replacement device and see if that fixes the issue. If not, it could be something interfering with the bluetooth connection.
    Sent from my DROID2 GLOBAL using Tapatalk
    Life begins, and spirits rise,
    and they become memories that vaporize,
    and the vapor becomes the dreams we devise,
    and while we are dreaming...
    Time flies...
  3. #3
    96896
    Sep 2011
    44
    I'm not familiar with the ghosting term. Idk but it's annoying.
  4. #4
    155951
    Jan 2012
    Philadelphia, PA
    I have the same problem with the Kensington Keyfolio Pro, MODEL #: K39357US . Does anyone know if this is a common problem with this keyboard? Are there better keyboards out there for the iPad2? Also, how do you get the on-screen keyboard to reappear on the iPad2 once you close it? Thanks!
  5. #5
    152796
    468 times
    Jan 2012
    NH
    343
    Not a plug, but I got the Belkin kbd folio for my iPad2 and love it. Good key feel, very very close to standard size desktop keyboard, so typing is quick. I'm still not quite used to hitting the space bar as hard as it requires, so I keep smooshing words together (not that it requires hitting it HARD; it's just a little harder than what I'm accustomed to). The iLounge review is pretty good, has pictures and such. No problems with it in a few weeks of actually doing some real writing on the thing, like the way it folds up so you can pretend it doesn't even exist. You can sit it upright on a desk and freely adjust the angles, so it's like a laptop. Or you can just fold the kbd out below the iPad and sit the whole thing on your lap fairly comfortably. Very happy with the folio/kbd.
    The Belkin kbd does have a keyboard button on it, so if I want the software kbd to appear back on the screen, I just press the key on my Belkin and the on-screen kbd appears. Love the Select All key, too.
    Sorry this doesn't address your issue directly, but thought I'd make the suggestion.
  6. #6
    181312
    Mar 2012
    Atlanta, Ga
    repeating keyssssssssss
    same Kens unit, iPad 3rd gen..... , same repeating keyssssss prob.... sent problem report to Kensington..... will respond when and if they do...... normally they are good with response... if this is the only problem we have, then it will work...
  7. #7
    181312
    Mar 2012
    Atlanta, Ga
    Kensington Technical Support replied and "it worked fine"
    Thank you for contacting Kensington Technical Support.
    We understand that you are experiencing difficulties with the KeyFolio Pro Keyboard Case for new iPad & iPad 2 model # 39357. In this regards, as a basic step of troubleshooting we suggest you to perform the following steps and check if it resolves the issue.
    1. Turn OFF the iPad and KeyFolio.
    2. Turn On the iPad and KeyFolio.
    3. Reconnect the iPad with KeyFolio and check if the KeyFolio works fine.
    after following these procedures, the unit keybd worked fine.... will now wait for re-occourance
    Hope this works for the above users
Sponsors
  1. Kensington Keyfolio - Troubles....Ideas?
    By domsdabomb in forum iPad Help
    Last Post: 03-18-2012, 08:40 AM
  2. ZaggMate, Brookstone or Kensington - Trying to decide
    By juniorgolf18 in forum iPad Accessories
    Last Post: 12-09-2011, 09:05 PM
  3. Kensington KeyFolio Pro Review
    By targa88 in forum iPad Accessories
    Last Post: 09-22-2011, 09:35 PM
  4. kensington case w/BT keyboard
    By jmorton10 in forum iPad 2 Forum
    Last Post: 04-17-2011, 05:33 PM
  5. kensington keyboard
    By Pluto5680 in forum iPad Accessories
    Last Post: 02-04-2011, 01:37 PM
kensington bluetooth keyboard not connecting
kensington bluetooth keyboard troubleshooting
kensington folio pro 2
kensington ipad keyboard problems
kensington ipad keyboard troubleshooting
kensington keyboard letter repeating on ipad
kensington keyboard not working for ipad
kensington keyfolio pro 2 problems with bluetooth
kensington keyfolio pro 2 review
kensington keyfolio pro 2 reviews
kensington keyfolio pro 39357
kensington keyfolio pro troubleshoot
kensington keyfolio pro troubleshooting
kensington keyfolio troubleshooting
keybord issues with repeating kensington
keyfolio pro 2
keyfolio pro connection problems
problems kensington bluetooth ipad
trouble shooting kensington bluetooth key board
