Camera Connection Kit
This is a discussion on Camera Connection Kit within the iPad Accessories forums, part of the Apple iPad Discussions category; Hi, I have recently purchased a 16gb iPad 2 (and love it!!). However, due to the limited memory I also purchased a camera connection kit, ...
Results 1 to 10 of 11
    77348
    Jul 2011
    5
    Question Camera Connection Kit
    Hi,
    I have recently purchased a 16gb iPad 2 (and love it!!). However, due to the limited memory I also purchased a camera connection kit, thinking that I could store photos and videos on SD cards that I could carry with me. This has worked a treat for photos - I've simply connected the camera kit, inserted the SD card and a message appears on my iPad screen asking which photo's I want to import.
    I have not been as successful with video's. These are video's that I've ripped from DVDs using Handbrake. As far as I can make out (I'm not extremely technical) all are in MPEG 4 format with a file extension of .M4v (I have used the iPad Preset in Handbrake when ripping). When I put the SD card into the camera kit nothing happens (or at least there is no message on the iPad screen). Would anyone have any idea's on where I'm going wrong or even if I should be able to read the video formats in the first place?
    thanks
  2. #2
    129720
    7 times
    Nov 2011
    Redneck Country
    318
    You can only get DVD's/M4v movies into the Video directory by using iTunes
  3. #3
    77348
    Jul 2011
    5
    That means I'd need to store them on the iPad hard drive rather than being able to keep them on the SD cards - is that right?
    I thought the camera kit said it could be used for photos and videos.
  4. #4
    129720
    7 times
    Nov 2011
    Redneck Country
    318
    Only if the video was made/shot from the camera can it be transferred to the ipad by the camera kit
  5. #5
    129720
    7 times
    Nov 2011
    Redneck Country
    318
    Hmmm on second thought I think there might be a way to trick the ipad to let you view the DVD/s on the SD Card. Give me a few and let me try something. My camera battery is dead so I need to charge it first.
  6. #6
    iPad Addict
    49414
    40 times
    North Carolina
    1,441
    Quote Originally Posted by Wexfordlady View Post
    Hi Wexfordlady - welcome to the forum!
    Well, might still be an 'iffy' possibility - check THIS LINK for a suggested solution but not a guarantee, I guess.
    Now I own the CCK and have easily imported many still images and a few videos made from my digital camera, so the latter for getting videos onto the iPad certainly works; these files are stored in the DCIM folder of the camera's SD card (which is the one needed w/ the CCK) - I have put images from my computer into this folder and have been able to import them (labeling may be an issue, though?) - have not tried videos, but take a look at the link and decide if you want to give it a try.
    Others who may have been successful may 'chime in' - and if the steps in the article work for you, please report back; this is likely a common desire of many - good luck!
  7. #7
    129720
    7 times
    Nov 2011
    Redneck Country
    318
    Ok I was able to do it but be warned because of the format the ipad needs to see the DVD files on the SD Card the quality of the movie is real bad. How I did it. 1st, when you rip the DVD it has to be ripped to the .MOV format and the file must have a name the ipad will see. How I found out. I shot a small sample video with my camera and then looked at what name my camera gave the file "100_1056.MOV" The next sample video I shot was named "100_1057.MOV So, if you put movies on SD cards they MUST be in the directory your camera creates when it shots a video and the names must be in order like
    100_1057.MOV
    100_1058.MOV
    100_1059.MOV
    100_1060.MOV
    and so on. Means you will not be able to give your movie custom names as the ipad will see them.
    Hope this helps
  8. #8
    129720
    7 times
    Nov 2011
    Redneck Country
    318
    Was able to copy a .mv4 from the SDCard to the ipad but it has to be in the file format name the camera gives the file.
    Such as
    100_1057.M4V
    100_1058.M4V
    100_1059.M4V
    100_1060.M4V
    And so on
  9. #9
    iPad Addict
    49414
    40 times
    North Carolina
    1,441
    Hello Randy - thanks for your efforts!
    As stated, I've put still photos on the camera's SD card and had to re-label them w/ special numbering too - kind of a PITA! So, I suspected that trying to get movies onto the iPad in that fashion would be a similar pain - let's cross our fingers for improvements in the next iOS release (or the next iPad)?
  10. #10
    129720
    7 times
    Nov 2011
    Redneck Country
    318
    Quote Originally Posted by giradman View Post
    I'm with you there.
Sponsors
  1. ipad camera connection kit drops connection
    By stingray1059 in forum iPad Help
    Last Post: 12-25-2011, 06:19 PM
  2. Help With Camera Connection Kit
    By Dave in forum iPad Help
    Last Post: 09-06-2011, 04:41 PM
  3. Camera Connection Kit
    By luwanda in forum iPad Accessories
    Last Post: 07-22-2011, 09:10 AM
  4. Replies: 3
  5. Camera Connection Kit with Panasonic LX3 Digital Camera
    By Atwell in forum iPad Accessories
    Last Post: 07-23-2010, 08:35 AM
.m4v camera connection kit
apple ipad camera connection kit handbrake 2012
camera connection
camera connection kit ipad 2 copy movie file format
camera connection kit panasonic sd card
camera connection kit won't recognize m4v
can i drop .mv4 on my ipad
copy m4v from sd card to ipad
handbrake camera connection kit
ipad 2 camera connection kit movies
ipad camera connection kit nothing happens
ipad camera connection kit. limit
ipad transfer kit m4v
is there a limit on sd card on camera conection kid for ipad
limit on ipad sd card cck
m4v camera connection ipad
transfer m4v to ipad with sd card
transfering movires to ipad 3 using camea connection kit
