ZAGG InvisibleSHIELD for iPad 2 Problem
This is a discussion on ZAGG InvisibleSHIELD for iPad 2 Problem within the iPad Accessories forums, part of the Apple iPad Discussions category; I have recently purchased ZAGG's InvisibleSHIELD for my new iPad 2, but encountered a problem about the second day after installation. Now when I turn ...
I have recently purchased ZAGG's InvisibleSHIELD for my new iPad 2, but encountered a problem about the second day after installation. Now when I turn on my iPad, the screen appears blurry and wet, as if the ZAGG iPad 2 Spray Solution that I used is still wet on top of the iPad screen. I regret purchasing the InvisibleSHIELD because of this, but I am not willing to take it off without the help of a professional at the local G2 Computers store. I tried waiting a few days to see if the screen would adapt and look different, but nothing changed. Does anybody know a way to successfully (and safely) get rid of the irritating blurry screen?
12-30-2011 04:04 PM
iPad Addict
Check your PM for relevant link.
Good luck.
Hey youngster, my uncle had the same problem of wetting after applying the invisble shield, its the problem with the ipad screen not the guard you've applied. The ipad surface is not flat that's the reason why there is wetness , my uncle has asked for a replacement with the apple store for which they replied it will be done at the earliest possible time. I think you have to ask the apple store guys . Good luck
I also experienced the same problem as TS,
now do not know what to do
- You may not post replies
- You may not edit your posts
Forum Rules
By chesterhound in forum iPad Accessories
Last Post: 01-24-2012, 08:47 AM
By icsaszar in forum iPad Accessories
Last Post: 07-03-2011, 09:42 AM
By raj2ad in forum iPad Accessories
Last Post: 03-27-2011, 04:14 PM
By wot_fan in forum iPad Accessories
Last Post: 02-27-2011, 02:43 PM
By dproudfo in forum iPad Accessories
Last Post: 01-04-2011, 06:13 AM
invisible shield blurry
invisible shield problems
invisibleshield blurry
invisibleshield ipad 2
invisishield for ipad 2
invisishield ipad 2
ipad 2 invisibleshield
ipad invisible shield blurry
issues with invisishield
problem with zagg invisible shield
problems with zagg invisible shield
zagg invisible shield blurry
zagg invisible shield for ipad 2
zagg invisibleshield blurry
zagg invisibleshield for apple ipad 2
zagg invisibleshield for ipad 2
zagg invisibleshield ipad 2
zagg invisibleshield problems
zagg invisishield problems
zagg ipad2 invisibleshield use for new ipad
