Non-leather case that doesn't block camera connection kit?
This is a discussion on Non-leather case that doesn't block camera connection kit? within the iPad Accessories forums, part of the Apple iPad Discussions category; I plan on buying an iPad 2 soon, so I've been researching cases like mad. I will be using the camera connection kit (allows you ...
Results 1 to 3 of 3
    110766
    Oct 2011
    Lawrence, KS
    11
    I plan on buying an iPad 2 soon, so I've been researching cases like mad. I will be using the camera connection kit (allows you to plug USB and SD cards in, I'll be using it for a MIDI keyboard), and I know some cases don't allow enough room around the port for the kit to plug in. What case do you use with your camera connection kit? I don't want to use a leather case. Fake leather is okay.
    Here's what I've come up with so far:
    Griffin Survivor - case does NOT fit the camera connection kit. Won't consider this one.
    Casecrown - some reviews on Amazon said the iPad can fall out and the case doesn't wake it from sleep. Still might consider this case though, as the reviews are overall very good
    Link: Amazon.com: CaseCrown Apple iPad 2 Bold Standby case (Black) for iPad 2 (Built-in magnet for Apple Smart Cover's sleep & awake): Electronics
    Khomo Dual Case - good reviews, 40 reviews, no 1 star reviews. However, doesn't fit camera connection kit and the front magnet thing is flimsy - guess I won't be getting this one.
    Link: Amazon.com: KHOMO DUAL CASE: Polyurethane Smart Cover FRONT + Hard Rubberized Poly-carbonate BACK Protector for Apple iPad 2: Electronics
    Targus Versavu - apparently the iPad gets smudges on the screen and slips out. This one is out
    Otterbox Defender - I'm considering this. Don't know about camera connection kit though. Anybody?
    Mware C.E.O. Hybrid - 60 reviews on Amazon, 4/5 stars. Has some pretty bad 1 star reviews though. Don't know about camera connection kit.
    Link: Amazon.com: Customer Reviews: Marware C.E.O. Hybrid for iPad 2 Black (602956007722)
    Well, what case do you have, and what do you think about it?
  2. #2
    87727
    Aug 2011
    Florida
    12
    I am a novice at this, but I have to ask the question: have you verified that the camera connection kit (usb) and Ipad will support a MIDI keyboard? I use the Yoobao executive leather and find that the leather can be moved out of the way to use the 30 pin port.
  3. #3
    87727
    Aug 2011
    Florida
    12
    Supplemental:
    In my response above, note that I have only used the charging plug so far in the 30 pin port. Is the Camera connection kit plug wider?
Sponsors
  1. ipad camera connection kit drops connection
    By stingray1059 in forum iPad Help
    Last Post: 12-25-2011, 06:19 PM
  2. Replies: 2
    Last Post: 06-04-2011, 02:16 PM
  3. Will a Case Block 3G Signals?
    By ColtsSN in forum iPad 2 Forum
    Last Post: 04-14-2011, 02:23 PM
  4. Replies: 3
  5. Replies: 2
    Last Post: 07-17-2010, 12:54 PM
best non leather ipad 2 case
does apple camera connection kit fit into griffin case
does camera connection kit fit otterbox defender
does camera kit work with griffin survivor
does survivor ipad case work with camera connection
griffin ipad camera connection kit case
griffin ipad case hack camera connection kit
griffin survivor ipad 2 blocks camera connector
ipad 2 case non leather
ipad 2 cases no lether
ipad 2 non leather case
ipad camera connection won't fit case
ipad case thatvdoesnt block camera
khomo case ipad review
marware ceo camera connector
non-leather ipad 2 case
non-leather ipad case
survivor case blocks camera
using ipad camera connection kit with griffen case
