Can anybody recommend a nice quality case that had a built in stand for using on a table, or on an airplane so I done need to hold it in my hand or on my lap? Thanks
This is a discussion on Need a case with a built in stand within the iPad Accessories forums, part of the Apple iPad Discussions category; Can anybody recommend a nice quality case that had a built in stand for using on a table, or on an airplane so I done ...
Nevermind...I bought a Tuff Luv Napa leather case / stand. Expensive but all reviews were posative.
Is it thin but still stable? Can you post a pic?
I was all set to buy the Napa case till I read this review.
First Looks: I-nique Tuff-Luv Bi-Axis, Multi-View + Pull-Tab Leather Cases for iPad | iLounge
My superpower
I have the unique ability to see through bull**** from a mile away.
i'm quite happy with my Apple case. I'm using it now on my knees angled in typing mode with my Microsoft BT keyboard. it tilts at a nice angle.
I can also stand it on the narrow end in "movie" mode and put it on a TV table.
Just look on Amazon, they sell it. Napa Leather and not the Bi-stand model.
First you said it was leather, then you said it's not leather, then you say it's leather again. The Napa Multi View case is only available in leather and is the exact case that iLounge gave a bad review to.
I've looked on the Tuff-Luv website and the only Napa case they sell for the iPad they sell is leather.
I guess that's why you cannot provide a link to this non-existent Napa non-leather case.
My superpower
