anyone have any suggestions for a bargain screen, or a cheap diy screen?
This is a discussion on ipad hooked up to my AAXA M2 LED Micro Projector within the iPad Accessories forums, part of the Apple iPad Discussions category; anyone have any suggestions for a bargain screen, or a cheap diy screen?...
I found in b&q a massive piece of thin chipboard with one smooth laminated white side. Thing only cost like £7. I painted a boarder on it and screwed it to the wall. Got a 63 inch picture on it.
pretty cheap i might go ahead and try that thx
i couldnt find what you got.. any suggestions where i could get something like that in the US?
Bummer. Urm, if you could find a piece of chipboard with a smooth surface you could always paint it White with semi-gloss?.
Just in case.... Is called White Faced Hardboard
http://www.diy.com/diy/jsp/bq/nav.js...=length_1819mm
