USB camera kit used to read pdf files from a USB flash Drive
This is a discussion on USB camera kit used to read pdf files from a USB flash Drive within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; Has anyone tried to read PDF files stored on a USB flash drive with the USB camera connector kit for the Ipad?...
Results 1 to 3 of 3
    13038
    Aug 2010
    Question USB camera kit used to read pdf files from a USB flash Drive
    6335
    Jun 2010
    13
    Yes, I managed to read PDF, AVI, JPG from flash drive.
    1. You need to have jailbreak applied to your IPAD.
    2. I tried with a USB flash drive of 1Gb and that worked fine. I tried with a 16Gb, but that one needed more power to operate.
    When plugging the USB key, open iFile and the external drive should appear. Select your PDF document and open with the selected app.
    13430
    Aug 2010
    Works as described, but something's missing
    I use the exact recipe Nickbt provided and it works perfectly. Have copied many megabytes of pdfs, music, images, movies, and work files.
    Only thing I could use help on is that I can't crack the code (yet) on how to get the images, music and movie files to show up in the Ipod app the same way as if I had used Itunes. Using Ifile, I've found that every other app has an easy to find 'documents' folder and copying files into these folders results in new items being visible the next time the app loads.
    However, for music, pictures and movies, I have to make my own little folder structure and then use Ifile exclusively to start the viewing/listening process. This isn't too bad, but a bit tiresome each time you want to look at something or listen to tunes.
    Have experimented and copied files into where the pictures and ipod apps place items, but the only folder that seems to pickup manually inserted files is the 'camera roll' folder. And even then, it's fussy and sometimes you'll see an image outline, with no proper thumbnail.
    Also, if you create a DCIM folder on the USB stick, and place pictures in the folder ... when you insert the USB stick, the pictures will be automatically inserted into the camera roll.
    Anyone know of an easy way to manually manipulate the music, images and movie folders. Ideally, I'd like to NEVER sync to Itunes again and ONLY use network shares and USB sticks.
    Thanks,
    W.
  1. Wireless Flash Drive
    By wot_fan in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-02-2010, 07:17 PM
  2. Can iBook read txt files?
    By Naox in forum iBooks
    Last Post: 07-27-2010, 06:54 AM
  3. External Hard Drive & Camera Kit
    By o_mega05 in forum iPad Hacking
    Last Post: 07-26-2010, 11:29 PM
  4. mapping a drive to ipad.. is it possible?
    By Coco B in forum iPad Help
    Last Post: 07-16-2010, 12:51 PM
  5. App to read Camera RAW?
    By kilofox in forum iPad Apps
    Last Post: 03-21-2010, 06:39 PM
camera read as drive
how to read a flash drive on an ipad
ipad connection kit read pdf
ipad read pdf from usb
ipad usb flash pdf files
read pdf from flash drive on ipad
read pdf from usb on ipad
who to read usb by ipad
