does bluetooth enabled device drain ipad battery?
This is a discussion on does bluetooth enabled device drain ipad battery? within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; I recently purchased a Logitech solar powered keyboard/case for my iPad2. I noticed that after leaving it in the closed case for a few hours ...
Results 1 to 4 of 4
    171607
    Mar 2012
    46
    I recently purchased a Logitech solar powered keyboard/case for my iPad2. I noticed that after leaving it in the closed case for a few hours that the iPad battery was soon depleted. There were no instructions stating that the bluetooth needed to be turned off when not in use. My question is, does bluetooth use the iPad battery when left on?
    49720
    277 times
    SC
    5,365
    Quote Originally Posted by foothillfanatic
    Bluetooth uses an antenna to send and receive signals. Thus, it uses energy. I have BT on all the time for my phone, but it goes to sleep when one of its pairing devices is not near by. I have my phone paired to my car and to a speaker. Heck, it is enabled right now on my iPad. But the BT icon in the upper right corner of the screen is greeted out, so BT is not on. But since nothing is in range it turns itself off. If you leave two devices close then BT stays on if they can "talk" to each other.....the battery drain can be very rapid then. In my car, my phone will get warm (indicating battery drain) when streaming music, so I keep it on the charger. I haven't noticed this with my keyboard, but they are very close together and there is much less info to transfer. So, yes, BT can drain the battery under certain circumstances, but it is also smart enough to go to sleep the the pairing cannot be maintained....and you typically have to wake it up to re-establish a connection. But that seems to depend...my phone always wakes up when I get in my car, but my keyboard and speakers don't. This might be device dependent, somehow.
    171607
    Mar 2012
    46
    I guess that is what's happening, as when I turned off BT on the iPad, the battery did not drain rapidly. I don't think the Logitech keyboard turns off automatically after not being used for awhile. When I manually shut it off the BT symbol on the iPad screen does disappear. So guess I'll have to shut off the BT on both the keyboard and iPad to minimize battery drain. Thanks for the help! Even while typing this post the iPad battery showed 3% loss. Seems BT is powerhungry.
    49720
    277 times
    SC
    5,365
    Quote Originally Posted by foothillfanatic View Post
    It probably is better to turn if off, especially if you can't charge it often.
  1. iPad Battery Drain
    By SallySparrow in forum iPad General Discussions
    Last Post: 04-26-2013, 07:00 AM
  2. IPAD 3, Not charging after battery drain....
    By waffles07 in forum iPad 3 Forum
    Last Post: 06-19-2012, 08:18 AM
  3. Battery Drain On iPad-2
    By Ayoade_Page in forum iPad General Discussions
    Last Post: 12-24-2011, 02:54 AM
  4. Jailbroken iPad (4.2.1) not rebooting after battery drain
    By radumarinescu in forum iPad Hacking
    Last Post: 06-17-2011, 09:59 AM
  5. Connecting iPad To A Bluetooth Enabled Car Stereo
    By Munky in forum iPad General Discussions
    Last Post: 05-29-2011, 02:43 PM
bluetooth drain ipad battery
does bluetooth drain battery
does bluetooth drain ipad 2 battery
does bluetooth drain ipad battery
does bluetooth drain iphone battery
does bluetooth keyboard drain ipad battery
does enable bluetooth on ipad lower battery
ipad 3 bluetooth battery drain
ipad bluetooth battery drain
ipad bluetooth drain battery
iphone bluetooth battery drain
will bluetooth drain iphone battery
