Smart cover problem..
This is a discussion on Smart cover problem.. within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; Does smart cover enhance heating problem?? Is thr any relation btwn smartcover and heating issue??...
Results 1 to 3 of 3
    206496
    May 2012
    Junagadh,Gujrat,India
    47
    49720
    277 times
    SC
    5,365
    Quote Originally Posted by Maitrey
    No.
    Moderator
    131244
    610 times
    Dec 2011
    Regina,Canada
    14,417
    If anything,the smart cover when closed would reduce the drain on the battery and alleviate any possible heating problem.After all,the smart cover when closed,normally turns off the display which is the biggest power drain on the iPad.
  1. suggest me good ipad3 smart cover compatible back cover
    By Vishal in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-23-2012, 05:45 AM
  2. Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution
    By fausley in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-08-2012, 10:52 AM
  3. Odd problem with the Smart Cover?
    By IrvSp in forum iPad 2 Forum
    Last Post: 12-01-2011, 08:51 PM
  4. iPad 2 iMessage smart cover problem
    By anonchi in forum iPad 2 Forum
    Last Post: 10-17-2011, 02:37 AM
  5. Problem with smart cover
    By Milliebert in forum iPad 2 Forum
    Last Post: 08-05-2011, 05:15 AM
apple smart case heat issues
does the apple smart cover drain battery
ipad 4 heating smart case
ipad magnetic cover problem
ipad smart case and heat
ipad smart case heat
ipad smart cover drains battery
ipad smart cover heat
ipad smart cover heat issues
new smart cover draining battery
smart case ipad heat
smart cover battery drain
