Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution
This is a discussion on Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; This is a fairly new brand, but they have a huge back case product line for the new iPad. They have soft case, hard shell ...
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By fausley
  • 1 Post By fausley
Thread: Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution
    196320
    3 times
    Apr 2012
    Chicago, IL
    12
    This is a fairly new brand, but they have a huge back case product line for the new iPad. They have soft case, hard shell case, case that is in solid color, and case that is translucent so you can show the Apple logo and the engraving.
    The cases are available on Amazon
    The price is just $15.99 - $19.99, and if you buy two of those, you get 20% off.
    Hard Shell: Amazon.com: KaysCase Smart Solution Hard Shell Smart Cover Compatible Back Cover Case for Apple iPad 3 3rd Generation - The New iPad (Clear): Computers & Accessories
    Soft Gel: Amazon.com: KaysCase Smart Solution Soft Gel Smart Cover Compatible Back Cover Case for Apple iPad 3 - the new iPad (Black): Computers & Accessories
    49720
    277 times
    SC
    5,365
    So have you used one of these?
    196320
    3 times
    Apr 2012
    Chicago, IL
    12
    Quote Originally Posted by AQ_OC View Post
    Not yet, I ordered the transparent blue hard shell case, which is back ordered til 4/28. I will wirte some reviews once I receive it.
    49720
    277 times
    SC
    5,365
    Quote Originally Posted by fausley
    Cool. Thanks.
    36910
    14 times
    Central Florida
    326
    Take a look at AppAdvice Daily. There is a video of covers and back covers done today and she likes the Soft Glow Hyper shield with the Apple magnetic cover.
    She also gives her opinion for a couple other products. The Hyper Shield was only $9.95 and very light weight with a choice of many cover colors. It is also transparent.
    196320
    3 times
    Apr 2012
    Chicago, IL
    12
    Just got the case today. I bought this one.
    Amazon.com: KaysCase Smart Solution Hard Shell Smart Cover Compatible Back Cover Case for Apple iPad 3 3rd Generation - The New iPad (Transparent Blue): Computers & Accessories
    Nice color, great feel, fits perfectly. I wanted a transparent blue case to go with my blue smart cover, and this is a only thing I can find at this price level, and I have no complaints.
    199144
    May 2012
    Columbus, Ohio
    12
    I have a KaysCase. It's very good. It's very similar to the Belkin snap shield, which is sold at 29.99 at retail stores.
    182191
    Mar 2012
    NC
    42
    Quote Originally Posted by fausley View Post
    Pics?
    196320
    3 times
    Apr 2012
    Chicago, IL
    12
    Here are the photos. Sorry it took so long as I was travelling.
    It's very pretty clear blue case, that fits perfectly, and shows the Apple logo.
    Attached Thumbnails Attached Thumbnails Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution-img_0109.jpg   Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution-img_0110.jpg   Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution-img_0111.jpg   Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution-img_0112.jpg   Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution-img_0113.jpg
    jpayne likes this.
    196320
    3 times
    Apr 2012
    Chicago, IL
    12
    KaysCase Smart Solution Hard Shell Smart Cover Compatible Back Case with Magnet Strip
    You are probably wondering what that dark strip is on the case. That is a magnet strip taped to the inside of the case, so when you fold the smart cover back to your iPad and read it as a book, the smart cover will be secured to the back of the case and will not flip around. I know some other cases are doing this. For example, the Belkin snap shield secure actually includes a small piece of metal strip on the case. The magnet tape is just a brilliant idea so you can make every back case a magnet secure case.
    I also bought the strip from KaysCase on Amazon
    Amazon.com: KaysCase Smart Solution Cover Case Magnet Partner for holding Smart Cover to the Case for Apple iPad 3 - the new iPad: Computers & Accessories
    I had a little fun cutting out my son's name with the strip. If you buy a KaysCase clear back case and a magnet strip, be creative with it, and upload a photo as a customer comments, they will give you the case for free.
    I don't have any pictures without the magnet strip, but the magnet strip is not part of the case. You can take it off and put it back on again. I do not want to do that because it took me forever to get it straight with the name on it, and really don't want to do it again.
    Attached Thumbnails Attached Thumbnails Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution-img_0114.jpg   Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution-img_0115.jpg   Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution-img_0116.jpg   Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution-img_0117.jpg
    jpayne likes this.
  1. suggest me good ipad3 smart cover compatible back cover
    By Vishal in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-23-2012, 05:45 AM
  2. An recommendation for Smart cover compatible back cover?
    By luvmac in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 11-22-2011, 11:24 PM
  3. Best case compatible with Smart Cover
    By Westec in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-27-2011, 04:37 AM
  4. TPU case that's *really* smart-cover compatible?
    By eN0ch in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-23-2011, 06:26 AM
  5. iPad 2 silicon case compatible with smart cover?
    By ghenealdz in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-09-2011, 02:08 PM
best back cover for ipad
best ipad 3 case compatible with smart cover
best ipad 4 smart cover compatible case
best smart cover compatible case for ipad 3
ipad 3 back case smart cover compatible
ipad 3 case smart cover compatible
ipad 3 case that works with smart cover
ipad 3 cases compatible with smart cover
ipad 3 smart cover compatible case
ipad 3 smart cover compatible cases
ipad back cover compatible with smart cover
smart cover compatible ipad 3 case
Tags for this Thread
