Results 1 to 4 of 4
    164457
    Feb 2012
    Yukon, OK
    6
    Using Netbook cart as an iPad cart
    Hello, has anyone used a netbook cart as an iPad 2 cart?
    I am specifically thinking about this one:
    Bretford 42 count netbook cart
    but I am worried about the Smart Brain working with iPad 2.
    Any suggestions or comments? All help is appreciated
    Thank you,
    Lisa
    160008
    Feb 2012
    PA
    It is a great idea. In fact, you can probably use any netbook or notebook cart that has enough outlets configured for the Apple plug. The Apple AC adapters draw 10 watts, so, even allowing for some inefficiencies, 40 iPads would be the equivalent to around four 100 watt light bulbs, which is no problem. You should not need a timer or a so-called "Smart Brain." It is just not worth the price.
    There are other charging carts that are compact and very secure. Security is really important. Someone recently said putting a cart full of iPads in a classroom is like putting in an ATM with an open card. My school got some great security carts from Datamation Systems and they are VERY secure. They have versions that store and charge 16, 20, 38, and 40 iPads.
    Also, make sure you get something that has adjustable slots or slots large enough for the cases you use now or may use some day in the future.
    Hope this helps.
    164457
    Feb 2012
    Yukon, OK
    6
    Thank you!
    197808
    Apr 2012
    New Jersey
    As Dan Mentioned, iPads do not require any smart brain electronics. There are many iPad carts available and many more to come.
    Although adjustable slots seem conveinent, wide iPad cases (over 1" wide) will reduce the capaciy of some carts from 40 to 30. Measure your iPad case width and call before making the purchase.
    Security is important! Plastic carts can easily be broken into within seconds. Any metal cart will significantly resist theft. If security is essential, call a dealer and speak to a real person.
    iPad carts cart capacities: 16, 30, 32 or 40
    JJC
  1. Replies: 7
    Last Post: 02-07-2012, 10:45 AM
  2. ipad for a sales catalog with add to cart?
    By Richard Rowe in forum iPad Apps
    Last Post: 09-20-2011, 08:14 AM
  3. Replies: 1
    Last Post: 09-03-2011, 05:39 AM
  4. add to cart option...
    By deco in forum iPad Apps
    Last Post: 07-07-2011, 06:46 AM
  5. Would I be ok with just an iPad & Netbook?
    By Voices in forum iPad General Discussions
    Last Post: 04-20-2010, 10:18 PM
anybody used smartbrain 2012
bretford netbook cart not charging ipads
cart as
ipad and netbook cart
ipad cart
ipad cart 42 slot
ipad cart adjustable slots
ipad cart forum
ipad cart vs netbook cart 2012
ipad carts
using an ipad cart
www.cartas .com br.
Tags for this Thread
