Non-leather case that doesn't block camera connection kit?
This is a discussion on Non-leather case that doesn't block camera connection kit? within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; I plan on buying an iPad 2 soon, so I've been researching cases like mad. I will be using the camera connection kit (allows you ...
Results 1 to 3 of 3
    110766
    Oct 2011
    Lawrence, KS
    11
    I plan on buying an iPad 2 soon, so I've been researching cases like mad. I will be using the camera connection kit (allows you to plug USB and SD cards in, I'll be using it for a MIDI keyboard), and I know some cases don't allow enough room around the port for the kit to plug in. What case do you use with your camera connection kit? I don't want to use a leather case. Fake leather is okay.
    Here's what I've come up with so far:
    Griffin Survivor - case does NOT fit the camera connection kit. Won't consider this one.
    Casecrown - some reviews on Amazon said the iPad can fall out and the case doesn't wake it from sleep. Still might consider this case though, as the reviews are overall very good
    Link: Amazon.com: CaseCrown Apple iPad 2 Bold Standby case (Black) for iPad 2 (Built-in magnet for Apple Smart Cover's sleep & awake): Electronics
    Khomo Dual Case - good reviews, 40 reviews, no 1 star reviews. However, doesn't fit camera connection kit and the front magnet thing is flimsy - guess I won't be getting this one.
    Link: Amazon.com: KHOMO DUAL CASE: Polyurethane Smart Cover FRONT + Hard Rubberized Poly-carbonate BACK Protector for Apple iPad 2: Electronics
    Targus Versavu - apparently the iPad gets smudges on the screen and slips out. This one is out
    Otterbox Defender - I'm considering this. Don't know about camera connection kit though. Anybody?
    Mware C.E.O. Hybrid - 60 reviews on Amazon, 4/5 stars. Has some pretty bad 1 star reviews though. Don't know about camera connection kit.
    Link: Amazon.com: Customer Reviews: Marware C.E.O. Hybrid for iPad 2 Black (602956007722)
    Well, what case do you have, and what do you think about it?
    87727
    Aug 2011
    Florida
    12
    I am a novice at this, but I have to ask the question: have you verified that the camera connection kit (usb) and Ipad will support a MIDI keyboard? I use the Yoobao executive leather and find that the leather can be moved out of the way to use the 30 pin port.
    87727
    Aug 2011
    Florida
    12
    Supplemental:
    In my response above, note that I have only used the charging plug so far in the 30 pin port. Is the Camera connection kit plug wider?
  1. ipad camera connection kit drops connection
    By stingray1059 in forum iPad Help
    Last Post: 12-25-2011, 06:19 PM
  2. YooBao iPad 2 case modification - now perfect leather case for me
    By gortyargen in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-04-2011, 02:16 PM
  3. Will a Case Block 3G Signals?
    By ColtsSN in forum iPad 2 Forum
    Last Post: 04-14-2011, 02:23 PM
  4. Replies: 3
  5. iPAd Accessories: Case, Keyboard Dock, USB, Camera Connection Kit
    By kemroon in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-17-2010, 12:54 PM
best non leather ipad 2 case
camera connection kit doesn't fit griffin
griffin survivor case camera connection kit doesn't fit
ioad camera kit wont fit
ipad 2 case non leather
ipad 2 non leather case
ipad camera connector kit fit smart case
ipad case built in camera connection kit
ipad2 non-leather keyboard case
modifying griffin survivor case for camera connection kit
non leather ipad 2 cases
suvivorcases
