Apple wireless keyboard battery problems
This is a discussion on Apple wireless keyboard battery problems within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; I have the apple wireless keyboard along with the Origami workstation case. I don't use the keyboard that often....maybe once every two weeks or so. ...
Results 1 to 6 of 6
    40727
    New Hampshire
    154
    I have the apple wireless keyboard along with the Origami workstation case. I don't use the keyboard that often....maybe once every two weeks or so. However, twice now when I take out the keyboard to use it the batteries are dead. What's up with this? I thought that it was supposed to shut itself off automatically? Is it possible that the Origami case is somehow pressing the keys and turning it on? I have bluetooth turned off on the ipad when not in use. I thought the batteries were supposed to last "for months" in this keyboard.
    I'd appreciate any ideas on this problem. Thanks.
    Mark
    Sent from my iPad2 using iPF
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    AFAIK Apple's BT keyboard doesn't have a "sleep mode". You'd have to push the power button on the RH side to turn it off.
    It's likely that the batteries are being drained when a key or keys are being pressed while in transit.
    FWIW I've had great success using rechargeable batteries in my Apple BT keyboard. (Sanyo eneloop). They last a good long time and I'm using it constantly (like now ).
    Hope that helps.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Another suggestion, which I do w/ electronic devices used infrequently is to simply remove the batteries, then reinsert when needed; a little inconvenient but works fine for me -
    iPad Addict
    121
    86 times
    Jan 2010
    Seattle, Washington USA
    1,293
    I've had an AWK for about five months. Use it fairly frequently. More precisely, it's almost always turned on when I'm viewing my iPad. According to the Apple website...
    "The Apple Wireless Keyboard requires just two AA batteries — one less than the previous model. And its intelligent power management system conserves battery life. So when you’re not using the keyboard, it automatically powers down. The instant you start typing, it turns back on. Use the on/off switch when you're away from your computer for a long time."
    I do make it a habit to turn off the keyboard when I'm in transit but that's primarily to prevent an accidental key press from starting the iPod application and playing music in my bag.
    Bottom line is that I've yet to replace the batteries, period. If, as you say, you don't use the keyboard a lot, I can't imagine depleting the batteries over a period of months.
    Another possibility (other than a faulty keyboard, of course) is that you have faulty batteries. Since it's happened to you twice, consider the possibility that you purchased a bad (or old) batch of batteries and you're just replacing one bad set with another. But if that isn't the case, it sounds as if you have a faulty keyboard. If I were you I'd take it back to Apple and explain the problem.
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Quote Originally Posted by jsh1120 View Post
    I've had an AWK for about five months. Use it fairly frequently. <snip>
    Good info...thanks for that!
    40727
    New Hampshire
    154
    All good ideas. Thanks for the information. If I have another problem with these new fresh batteries, it's going back to Apple.
  1. Apple's wireless keyboard
    By Plainsman in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-13-2011, 10:47 AM
  2. Replies: 2
    Last Post: 06-12-2011, 12:39 PM
  3. Apple Wireless Keyboard
    By jmbarker in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-25-2011, 09:48 AM
  4. Apple's Wireless Keyboard vs. Matias Wireless Folding Keyboard
    By WannaBeMac in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-23-2011, 08:36 PM
  5. Apple wireless keyboard
    By dennis in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-13-2010, 09:17 AM
apple battery keyboard problem ipad
apple wireless keyboard battery life 2011
apple wireless keyboard battery life ipad
apple wireless keyboard dies fast ipad
check apple wireless keyboard battery ipad
check battery level apple wireless keyboard ipad
how do i check battery life of apple wireless keyboard
how do i check the battery level on my apple wireless keyboard? ipad
how to check battery level on apple wireless keyboard
how to check battery on apple wireless keyboard from ipad
how to take out the batteries from the apple wireless keyboard
ipad wireless keyboard batery status
