GoFlex Satellite problems
This is a discussion on GoFlex Satellite problems within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; Originally Posted by Hbooooob_2004 when i connect goflex satellite to ipad without opening go flex media a browser open spontaneously . and it do not ...
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
  1. #21
    117393
    Oct 2011
    Ireland
    Quote Originally Posted by Hbooooob_2004 View Post
    when i connect goflex satellite to ipad without opening go flex media a browser open spontaneously . and it do not work promptly wz goflex satellite so i close it and open goflex media.i do not want that browser to open any help plz?
    Every time i connect to go flex satellite a message said in response to ios 6 plz update ur firmware but i updated and follow the instruction but the same message reappear thx
    You may be aware of all of this already but just in case you are not it is all I can suggest:
    For IOS 6, you need firmware Version 1.3.6.001 installed on the Goflex drive.
    How to check your firmware version and how to get the latest firmware update?
    From either the GoFlex Media app or the browser interface of the GoFlex Satellite, select Settings and look at top area where the firmware version number is displayed. Newer firmware will be posted on Document ID: 220011
    To determine what firmware version is running on a GoFlex Satellite follow these steps:
    1. Power on the GoFlex Satellite.
    2. Connect to the GoFlex Satellite's Wi-Fi network.
      For instructions in Windows, see Document ID: 219407.
      For instructions in MacOS, see Document ID:219403.
    3. Open an Internet browser (ie, Internet Explorer, Firefox, Chrome, Safari).
    4. Go to goflexsatellite dot com.
    5. Click Settings on the right of the screen.
    6. Read the Satellite software version (at the top of the screen on early versions, at the bottom of the screen on 1.1.0.005a and above).
    To install the new firmware on the Goflex drive:
    Step 1
    Fully charge the GoFlex Satellite drive.
    Step 2
    Exit the GoFlex Media App on your mobile or tablet device.
    Step 3
    Connect your GoFlex Satellite to your computer using the USB Adapter.
    Step 4
    DOWNLOAD the Satellite Firmware to your computer and copy the downloaded file to your GoFlex Satellite. (Do not put it in a folder)
    Note: Filename is satellite_firmware_xf_DVT_1.3.6.001.bin (do not rename this file)
    Step 5
    Safely remove the GoFlex Satellite drive.
    a. For Windows – use the safe remove hardware icon by the clock
    b. For Mac OS – click the eject icon in the finder in Mac OS.
    Step 6
    Disconnect the USB cable from the computer.
    Step 7
    Power on the GoFlex Satellite and let it update. (2-3 Minutes) DO NOT ATTEMPT to connect to the Satellite until the Wi-Fi light on the drive stops blinking. Once the Wi-Fi light stops blinking the GoFlex Satellite is ready to use.
    Some people claim that the Goflex will not update on an Apple Mac if that is the type of computer you have and that it must be done on a Windows PC. The stupid forum rules will not allow me post web page links to this or anything else.
  3. #22
    260489
    Nov 2012
    Cairo
    Quote Originally Posted by dellhell
    [*]Power on the GoFlex Satellite. [*]Connect to the GoFlex Satellite's Wi-Fi network.
    For instructions in MacOS, see Document ID:219403.[*]Open an Internet browser (ie, Internet Explorer, Firefox, Chrome, Safari). [*]Go to goflexsatellite dot com.[*]Click Settings on the right of the screen. [*]Read the Satellite software version (at the top of the screen on early versions, at the bottom of the screen on 1.1.0.005a and above).
    Step 1
    Step 2
    Step 3
    Step 4
    Step 5
    Step 6
    Step 7
    I can not tell u how thankfully I am thx again
  4. #23
    254263
    2 times
    Oct 2012
    Planet Cat, UK
    20
    Or you can do what I did, hack it
  5. #24
    117393
    Oct 2011
    Ireland
    No problem. Hope it helped. Now I am up to 3 posts I think I am allowed add links!
  6. #25
    278628
    Feb 2013
    uk
    Well I purchased this for my girlfriend who is a photographer/ cartoonist for xmas so she can carry her work around easily and show her potential clients her work on her IPad.
    Unfortunately we camm ot get this to work properly at all.
    We have updated the firmware and tried all other advice but a lot of the Jpeg images she loads onto the hard drive do not show up when connected either to her IPad or her desktop via wifi.
    They all show up correctly when connected via USB.
    I have been in contact with Seagate and their support team will not help at all.
    The most expensive door stop I have ever purchased.
    Will never go near Seagate again !!!
  7. #26
    49720
    279 times
    SC
    5,369
    Quote Originally Posted by rocketrob01 View Post
    That is a sad report. I thought they had gotten all the bugs out since I tried one of these in 2011. It was new then, but I sent mine back because it didn't work well at that time.
  8. #27
    118383
    Oct 2011
    Singapore
    8
    rocketrob01,
    Have you looked at the alternative firmware for the GoFlex Satellite ? I have been using it almost 20 months and it is working great for me. I am a photographer as well and they even have the EyeFi Server built in so that my photos gets uploaded automatically into the GoFlex Satellite.
  1. Seagate GoFlex Mobile Wireless Storage
    By xhuntercx in forum iPad General Discussions
    Last Post: 03-27-2012, 12:48 PM
  2. Seagate GoFlex Satellite?
    By RAC in forum iPad General Discussions
    Last Post: 11-07-2011, 02:26 AM
  3. Satellite mapping software
    By cipad in forum iPad Apps
    Last Post: 09-28-2011, 01:20 AM
  4. App to record from satellite or DVD on iPad?
    By Hollywood06 in forum iPad Hacking
    Last Post: 07-31-2011, 11:48 AM
  5. Satellite Flybys
    By slothead in forum iPad Apps
    Last Post: 03-04-2011, 05:34 AM
goflex media goodplayer
goflex satellite hack 8player
goflex satellite player
goflex satellite problems
goflex satellite stops broadcasting
goflex satellite troubleshooting
goflex satellite webdav
ipad with goflex and 8player
seagate goflex satellite webdav
seagate satellite problems
seagate satellite troubleshooting
url to transfer files from goflex wifi to oplayer hd
