Switcheasy Canvas problem
This is a discussion on Switcheasy Canvas problem within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; I've had mine for a couple of days and I'm very impressed, with one exception. When my iPad is "propped" in any of the 3 ...
Results 1 to 7 of 7
    42714
    104
    I've had mine for a couple of days and I'm very impressed, with one exception. When my iPad is "propped" in any of the 3 slots, it slides out extremely easy. A simple page turn can cause it. I invariably end up letting it slide all the way forward.
    Anyone else experiencing this?
    I've written Switcheasy on this. Interested to hear their thoughts.
    48391
    Herndon, VA
    7
    Just got my Canvas on Fri and your question actually got me up off the couch to see if mine had the same problem- it does not. I propped it up on the kitchen table in landscape configuration and tried it out in each 'notch'. After swatting at the screen like a cat pawing at a ball of yarn, it stayed put.
    However I can see how it would slip out of notch if not on an even, level surface.
    What color Canvas did you go with?
    EDIT - Yep, got mine to skip out of slot too. Happens when it is propped up and
    you tap the Top of the screen. Makes sense because that's where the lever action is maximized.
    Someone will come up with a trick to prevent this from happening that is better than setting your beer there to keep it in place
    iPad Enthusiast!
    44514
    35
    No, mine seems to fit very well, and is very secure when set up in the stand.
    Sent from my iPad 2 using iPF
    36299
    20 times
    500
    I don't have this case but I see this is a common problem with all folio style slot type cases. If you press on the top corners it May slip out. I've tried a work around using a rubber band which worked ok but now I've just learned to work with it.
    42129
    Michigan
    90
    I just tried mine too and it is a little easy to get it to slide when it is in the most upright position. The other ones are pretty stable.
    Sent from my 32 GB wifi Ipad 2
    41634
    Florida
    11
    I have the same problem. I also emailed Switchease and their reply was an email with return instructions. I was really hoping to speak with someone, not just to have to return it and take the chance of getting another one with the same issues, but of course there is no phone number for them.
    Quote Originally Posted by Mattmilw View Post
    Early-2011 MacBook Pro 13" i7 | 2011 iPhone 4S 32GB| 2011 iPad 2 64GB 3G| 2012 iPad 3rd Gen 64GB 4G LTE
    42250
    Riverside, CA
    103
    I use mine quite a bit.. Have not had a problem, I love it....
  1. Switch easy canvas iPad 2 case
    By Toscana in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-24-2011, 12:07 AM
  2. Canvas compatible ipad 2 dock
    By MatthewH12 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-21-2011, 10:47 PM
  3. Replies: 1
    Last Post: 04-18-2011, 10:05 PM
  4. Grove or Switcheasy Canvas?
    By doubledown7d in forum iPad 2 Forum
    Last Post: 04-18-2011, 02:36 PM
  5. Apple Canvas decoded.
    By iDan in forum Apple iPad News
    Last Post: 01-26-2010, 04:44 PM
canvas
how to fix switcheasy canvas
switch easy canvas problems
switcheasy canvas best color
switcheasy canvas colors
switcheasy canvas issues
switcheasy canvas problem
switcheasy canvas problems
switcheasy canvas slips
switcheasy canvas typing
switcheasy canvas typing position
switcheasy location
