Just do a search for Bodelin ProPrompter HDi.
ProPrompter iPad Bracket*
Use the ProPrompter iPad Bracket to attach to your tripod for off-camera or live-stage prompting. Attaches to any 1/4"-20 tripod mount or plate and securely holds your iPad.
Thanks guys. This is exactly what I was looking for.
ThePhotog
Please Support the Wounded Warrior Project
iPod 2nd 8GB, iPod nano 6th 16GB, iPod Classic 7th 160GB, iPhone 4 x 2 16GB, iPad 1 32 GB & iPad2 32GB Blk, 1 iPad 3 32GB Wifi 4G and a iPad 3 64GB Wifi.
It is for the iPad, not the iPad 2 which is slightly smaller and thinner. Be prepared to add a little padding to make it fit snugly.
iPad 2
Height: 9.50 inches (241.2 mm)
Width: 7.31 inches (185.7 mm)
Depth: 0.34 inch (8.8 mm)
iPad 1
Height: 9.56 inches
Width: 7.47 inches
Depth: 0.5 inch
Do you think I better wait for the iPad 2 version?
Maybe the iklip is also an option, allowing you to use the tripod for the camera and clipping this thing to a leg
See http://www.ikmultimedia.com/iklip/features/
Mathieu
iPad1 3G 64Gb - IOS 5.1 | iPad 3 3G 64Gb - IOS 6
After spending two hours building my own mount a friend sent me this link.
It's a tripod mount for iPad 2.
gadgetsource.info
kickstarter.com/projects/johnstump/iloqe-ipad-2-case-with-detachable-tripod-mount]iLoqk: iPad 2 case with detachable tripod mount by John Stump — Kickstarter
John
I finally ordered one from this company. Here is my synopsis.
www.iphone2in1tripodmount.com
They have a variety of Tripod Mount versions for the iPad 2 to Blackberry Phones to GPS ...etc.
I Rate this site ★★★★★ because of pricing, It's a patented product so I know its for real company. Light weight and the design is just great! It sports a 4" suction cup adapter with it; for multiple uses. Both front and rear Camera's are NOT obstructed during use! Rugged and Ready! I'm a freelance Photographer/Face-time User iPad 2 Lover. This works for me!
