Problem applying Zagg Invisible Shield
This is a discussion on Problem applying Zagg Invisible Shield within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; I found it impossible to position the Invisible Shield for placement onto my iPad. I followed all the steps but when it came time to ...
Results 1 to 10 of 16
    15670
    Sep 2010
    12
    I found it impossible to position the Invisible Shield for placement onto my iPad. I followed all the steps but when it came time to apply it, I just couldn't get the protector positioned correctly.
    Does anyone have tips on how to do this?
    Otherwise I'll just continue to go without a screen protector.
    19240
    Nov 2010
    I used a lot of that spray stuff, put it on both sides of the shield and on my hands. That made it slippery and I was able to scoot it where I wanted it.
    Also, I used a plastic kitchen tool to get the bubbles out. It's about four inches long and three inches wide. I use it to clean flour off my counter. Worked very well for getting the bubbles out.
    iPad Enthusiast!
    17138
    Oct 2010
    79
    Pay an installer
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    Exactly what dhanchey said.
    1. Find a clean workspace, let everyone else know to leave you alone for the next 30-45 mins, wash your hands thoroughly, dry them, clean your iPad surface until all the visible specks are gone.
    2. Then wet your fingers with the Zagg solution, get the InvisibleShield and wet it on both sides, and it should be quite straightforward to position the protective sheet when sufficiently lubricated. Apply the solution liberally (but take care you don't leak into the device itself!). If you run low, just refill it with water (per Zagg's instructions from their website.)
    3. Use a squeegee or cloth to press out all the bubbles, and allow it to dry out.
    I've done Zagg Invisibleshields for both iPhone and iPad, and didn't have much problems with it and it wasn't as troublesome as some reports made it out to be. (Not for me, anyway.)
    32GB WiFi
    19339
    Nov 2010
    I like the advice from tzimisce. One other thing that I might add is that since the iPad is so large. It helps to ask a friend to assist you with the alignment of the invisibleSHIELD. Some customers can do it alone without problems, but we recommend having another set of hands to help with that step. Make sure you friend wets their fingers as well.
    Another important thing I want to point out is with the SHIELDspray. You can refill the bottle with water, as mentioned above, but do not do this more then 3 times. There is enough residue on the bottle that filling it about 3/4 full with water 3 times it should work as the SHEILDspray would. I do not recommend doing this more then 3 times though.
    Did your invisibleSHIELD get damaged at all during the installation process? If so shoot me an email with your order number and I will get a new one sent out to you ASAP.
    Please let me know if I can assist you with anything in the future.
    ZAGGchick
    ZAGGchick(at)zagg.com
    iPad Enthusiast!
    17606
    Oct 2010
    29
    I paid someone at Best Buy to do it for me. He said, "this isn't hard" and i said "perhaps. But after trying to put a shield on a wacom cinitz monitor i wasn't in any mood. It took him over 20 minutes and he knew what he was doing.
    ALtho, i am fairly handy, (simple home repairs, serious darkroom building) i would have made a mess of the whole thing.
    It was well worth the 12 dollars
    iPad Master!
    5353
    4 times
    May 2010
    Fort Worth, TX
    661
    The key for me was keeping my hands wet enough. Its tricky, but doable.
    16596
    Oct 2010
    The Centre of The Universe, UK
    32
    I applied mine no problem, but then I'm used to doing film. However, the supplied squeegee scratched the 'military grade' film!
    14793
    Sep 2010
    Surrey, England
    30
    This was the first ever screen protector I have ever applied to any of my electronic gadgets and I found it a total breeze to apply.
    I did have a slight panic when pulling the film off the backing material when I managed to get it stuck to itself but it did pull apart (relatively easily) and all was well.
    I used a GOOD covering of the supplied wetting solution and it was much to my surprise really easy to slide it into position. I used a credit card to squeeze the excess solution out.
    Totally delighted with this and have no hesitation in saying I would buy this again.
    David
    15670
    Sep 2010
    12
    Thanks for the tips, esp. Zaggchick. It's not practical for me to get sent a replacement so I'll just go without a cover.
  1. Scratches in Invisible Shield
    By MrYummy in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-24-2011, 05:40 PM
  2. Want to buy a Zagg shield?
    By Itzxdjx in forum iPad General Discussions
    Last Post: 05-09-2011, 03:58 PM
  3. Zagg invisible Shield Questions(Part 2)
    By iPadUser in forum iPad General Discussions
    Last Post: 06-27-2010, 05:42 PM
  4. Zagg Invisible Shield - Application????
    By CMFox in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-09-2010, 08:38 AM
  5. Steinheil AF Antiglare shield
    By BuayaGuy in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-26-2010, 11:55 AM
applying zagg invisibleshield
how to apply zagg invisible shield
how to apply zagg invisible shield to ipad
how to use zagg invisible shield spray
invisible shield problems
invisible shield troubleshooting
invisibleshield for ipad problems
invisibleshield problem
invisibleshield problems
problems applying zagg invisible shield to ipad
zagg invisibleshield reapply
zagg problems
