Smart case or smart cover
This is a discussion on Smart case or smart cover within the iPad Accessories for iPAD 1, 2 and 3 forums, part of the Apple iPad Discussions category; Hi. At the moment I've got a smart case, light blue. But I want an easy case for home. And I would use my smart ...
Results 1 to 5 of 5
    222598
    Jul 2012
    65
    Hi. At the moment I've got a smart case, light blue. But I want an easy case for home. And I would use my smart case for travelling. Do you think this is a good idea. I have had a Smart Cover before but sold it for a smart case. I still like the smart case but I like to take it off sometimes and it's a bit fidilly. Thanks.
    49720
    277 times
    SC
    5,365
    Sure, if that's what you like. If you want to protect the back, consider getting a skin....like those from iCarbons.com or from bodyguardz.com. These are super thin and light, and stick to the back. They will protect from scratches and light dings...not from a drop. Then use your smart over to protect the screen when not in use. You should be able to use your smart case too because the skins take very little room and add essentially no bulk.
    222598
    Jul 2012
    65
    Quote Originally Posted by AQ_OC
    I was just thinking about using my Smart Cover at home (where it wouldn't get scratched) and use my smart case when I'm out.
    49720
    277 times
    SC
    5,365
    Quote Originally Posted by Jack1231 View Post
    Why would it not get scratched at home? For me, that's the most likely place to get a scratch!
    222598
    Jul 2012
    65
    Well at least when I'm out no one would see the scratches if I have my smart case on. And my iPad never get scratched really at home. Gets scratched more if I'm in a cafe or just out.
  1. Recommend a good Smart Cover compatible back cover case: KaysCase Smart Solution
    By fausley in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-08-2012, 10:52 AM
  2. Case or just smart cover?
    By reallydog in forum iPad 3 Forum
    Last Post: 04-01-2012, 09:32 AM
  3. Poetic Smart Shell Smart Cover Partner V2
    By mrogers07 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-06-2011, 05:03 PM
  4. Use the Smart Cover with a Gel Case
    By Griz in forum iPad 2 Forum
    Last Post: 05-24-2011, 09:59 AM
  5. Full iPad 2 Protection With Smart Cap + Smart Cover
    Last Post: 05-15-2011, 10:23 AM
