wifi issue
This is a discussion on wifi issue within the iPad 4 Forum forums, part of the Apple iPad Discussions category; Had my Apple cherry popped a week and a half ago when I got a 4th gen iPad that came with iOS 6. I also ...
Results 1 to 5 of 5
Thread: wifi issue
    267250
    Dec 2012
    Toledo, OH
    wifi issue
    Had my Apple cherry popped a week and a half ago when I got a 4th gen iPad that came with iOS 6. I also got the Smart Case for it at the time. When I first tried to use it to access my wifi at home, it was problematic for about an hour. After that, it has been smooth sailing since.
    Today, my LapDawg O Stand arrived. I chose this stand over others because it was flexible and I would be able to use it while it was still in the Smart Case. The ONLY reason I got a Smart Case in the first place is because of the way it turns the screen off automatically when you close it. While it was clamped into my O Stand though, I had to push the physical button to put it to sleep. Big mistake as I have not been able to use my iPad with my wifi since.
    At first, I thought maybe the stand itself was somehow interfering or diffusing the wifi signal. But out of the stand, out of the case, and much closer to my wireless router, the iPad continues to show excellent signal, but unable to use. I've reset my router several times now.
    I start looking online to see what I might be able to do. Apparently, iOS 6 has wifi issues, which would explain the issues I was having the first night I had it. Anyways, I did what was recommended by resetting network settings, turn HTTP proxy to auto, and clearing Safari's cache, history, etc. I continue to see excellent signal on my wifi, but I cannot do anything with the wifi.
    The part that's doing my head in is that every now and then, I get a very brief moment of clarity where I have full access to the wifi without issue. It doesn't last more than a minute though and is very few and far between. What can I possibly do? At on point, I even tried telling it to go ahead and install 6.01. It just sits there at verifying update. Which it cannot do because it doesn't know how to use my wifi! derp
    [EDIT]
    Sorry, forgot to add that throughout all of the above, my PC has been able to use the internet without issue.
    Moderator
    131244
    643 times
    Dec 2011
    Regina,Canada
    14,722
    Have you tried going to Settings>General>Reset>Reset Network Settings? This has been known to help with other users with your problem.
    267250
    Dec 2012
    Toledo, OH
    Yes, I did that. I thought I mentioned it in the opening post. Thanks anyways.
    Moderator
    131244
    643 times
    Dec 2011
    Regina,Canada
    14,722
    Quote Originally Posted by gtadem
    Have you thought about calling the toll free tech support number and seeing if Apple can offer any help. You get 90 days of free tech support when you bought your iPad. You may as well make use of it.
    267250
    Dec 2012
    Toledo, OH
    Well after trying over and over, I was finally able to get 6.0.1 to install and for now, I seem to be having no issues with wifi.
  1. Is this the wifi issue?
    By antisomnic in forum iPad 3 Forum
    Last Post: 04-23-2012, 05:20 PM
  2. Wifi issue on iOS 5.0.1
    By Squid in forum New Member Introductions - Site Assistance
    Last Post: 02-13-2012, 09:21 PM
  3. wifi issue
    By Driver in forum iPad Help
    Last Post: 12-16-2010, 02:22 PM
  4. Wifi Issue with OS 4.2
    By aramb in forum iPad Help
    Last Post: 12-11-2010, 03:55 PM
ios 6 wifi proxy auto
