Slow wifi tethering speed from Galaxy S3 to iPad 4 Wifi
This is a discussion on Slow wifi tethering speed from Galaxy S3 to iPad 4 Wifi within the iPad 4 Forum forums, part of the Apple iPad Discussions category; I have an iPad 4 the wifi version and a Galaxy S3. I'm using the S3 for wifi tethering for the ipad and I'm experiencing ...
Results 1 to 10 of 11
    200488
    May 2012
    Israel
    17
    I'm using the S3 for wifi tethering for the ipad and I'm experiencing very slow speeds and connection drops.
    I don't think it's a problem with my carrier because I did a speedtest on the Galaxy and the speeds were great, however the speeds on the ipad when tethered to the Galaxy were very slow but on my wifi home connection everything works great and the speeds are much better on the iPad.
    I was told in another forum that it might be a problem or incompatibility with the combination of the Galaxy with the iPad.
    Would the iPad work better with a portable hotspot device such as webbing spot or connect one for example (These are available in my country)?
    I would like to know what you think, if I could get significantly better speeds with the portable hotspot than what I get with the Galaxy.
    Thank you in advance for your help.
    White iPad 4 64gb Wifi
    263411
    6 times
    Dec 2012
    105
    Quote Originally Posted by Splashy
    I say it's that phone...I made the grave mistake of getting rid of my iPhone 4 for the galaxy and realized its junk....went back to iPhone 4S....but anyways it's a compatibility issue
    White 32GB iPad with Retina
    7684
    Jun 2010
    112
    That has not been my experience. I am using my GS3 with my Ipad 4 to write this comment. Speed is at 4G lte networks normal results and works great with FoxFi. Only difference could be that I am using the paid version of FoxFi.
    200488
    May 2012
    Israel
    17
    Thanks for the comments.
    I tried another cellular provider that's considered to have faster cellular internet and now the speeds are even slower, probably bad reception in my area, so I'm going back to my previous cellular provider.
    As for the compatibility issue with the iPad 4 and the Galaxy S3, I'm getting different responses from different people.
    Some people are also having similar problems with other Android devices tethering to an iPad.
    However, I don't think it's in my best interest to spend money on a cellular capable iPad when I don't use the GPS or buy an iPhone 5 because it's very expensive and I'm happy with my Galaxy S3.
    The question is, if it is indeed a compatibility issue, would I be better off with a portable hotspot device? People on other forums seem to think it won't make a difference but I still wonder.
    Thank you for your help.
    14699
    15 times
    Sep 2010
    Woodlands MB, Canada
    392
    I've got the Galaxy Note II (which is essentially a larger S3) and an iPad 1. The phone is new and I've never tried tethering so your post made me curious as to how my Samsung and Apple products would work together. I used the ookla speed test app to determine the speeds (see link below). Our network is 4G (No LTE yet )
    https://itunes.apple.com/ca/app/spee...300704847?mt=8
    My phone alone gave me a 5.99 Megabits per second download speed using the Android version of the app. The iPad tethered to the Samsung via WiFi produced a 6.75 Megabits per second. It was little faster.. No doubt there was some sort of network or server congestion that lowered the first test. I suppose a series of tests averaged over several days would probably produce more similar results..
    This has me thinking now... I originally got a WiFi+3G iPad because my phone back then had no ability to tether. If I use my Samsung Note I'll be able to get 4G speed on my 3G iPad. I might not have helped you, but I'm glad I read your post
    263322
    Dec 2012
    Phoenix AZ
    11
    For what's it worth just went to my s3 and set up my hotspot. Logged in with my iPad4 and vroooooom. No speed issues here with Verizon 4g.
    iPad 4
    Kindle File (Rooted)
    Galaxy S3
    135236
    3 times
    Dec 2011
    58
    Quote Originally Posted by Mojosodope View Post
    Junk? Did you actually give it time as Android is a completely different setup to IOS?
    I have used both Apple and Android and yes both have their advantages, but I would not describe either as 'junk', My Samsung Galaxy Note 2 is really nice, but not perfect, but I will say one thing, alot of Apple users use Android for a short time but don't explore the full functions and give up too soon. I must admit IOS is easier to use but Android is more customizable (if thats a word) and before you say it, yes the IOS can be jail broken but its a hack, just like rooting the Android, to me, hacking the thing just takes away the fun of learning the basics and for most of the time, voids the warranty.
    So my advice to potential Android users, give it some time before you decide what to do, its not the same as IOS.
    PS: Sorry for going off topic.
    Moderator
    131244
    1426 times
    Dec 2011
    Regina,Canada
    18,544
    Have you thought of the possibility that the WiFi hotspot on your phone may not be working properly? Have you tried connecting other devices to the hotspot, such as your laptop?
    200488
    May 2012
    Israel
    17
    My laptop gets 4Mbps and my iPad 4 gets 2Mbps tethered to the Galaxy.
    Both get much faster speeds (16-20Mbps) from my home network.
    Now it works better, even though it's only 2Mbps the speed is reasonable unlike it was before.
    Maybe it was a temporary problem. Let's hope it continues to work well.
    263411
    6 times
    Dec 2012
    105
    Quote Originally Posted by evohicks
    I gave it a full year...attempted to root it which was harder than anything I've done only to brick one device, GPS never worked and the company said it was ok, the updates especially never came to my phone when they were released and when they did come out 3 months after launch you actually had to sit at your computer with the phone and download the file to the computer first, then to the phone which took 45 min, it didn't allow me to put all my music on my phone, the SMS feature was awful, I can go on but I won't. So yes I gave it time. My dad has the note 2 and its an awesome phone. But the galaxy phones are awful
  1. Replies: 13
    Last Post: 03-20-2012, 09:29 PM
  2. GPS Tethering on wifi iPad?
    By Gzoladz in forum iPad Help
    Last Post: 07-12-2011, 03:29 PM
  3. iPad WiFi to Router Speed?
    By jdag in forum iPad OS
    Last Post: 04-16-2011, 05:37 PM
  4. Iphone 3GS tethering to my iPad 16gb WiFi only
    By laserguy007 in forum iPad Help
    Last Post: 01-29-2011, 07:30 AM
  5. Wifi vs 3G wifi speed/reception
    By CPMS in forum iPad General Discussions
    Last Post: 05-03-2010, 10:25 AM
apple samsung hotspot slow
how to tether samsung note 2 to ipad
i am useing 3g net work and tether portable hotspot for my laptop after 3 a clock its very slow
my galaxy s3 wifi hotspot is slow
s3 hotspot slow
samsung galaxy s3 as hotspot for ipad
samsung s3 hotspots very slow
tether samsung s4 to ipad
