Problem with wifi connection
This is a discussion on Problem with wifi connection within the iPad 4 Forum forums, part of the Apple iPad Discussions category; Originally Posted by scifan57 Did you update to iOS 6.0.2? This update was supposed to fix WiFi issues on the iPad mini and the iPhone ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    270903
    Jan 2013
    Question
    Quote Originally Posted by scifan57 View Post
    Did you update to iOS 6.0.2? This update was supposed to fix WiFi issues on the iPad mini and the iPhone 5.
    Yep, it's 6.0.2 all right.
    The funny thing is that for about the first 2-3 seconds, it runs right up there at 13-14 Mb then it drops to 2-3 and stays there for the rest of the test. It can do it but something stops it.
    I don't seem to have that problem with the iPad 1 I use. It seems to work just as well as the newer ones albeit it weighs a lot.
  3. #12
    259404
    Nov 2012
    New Jersey
    22
    That's exactly what happens but I have the iPad 4! No update for that! Interesting, thanks.
  4. #13
    271731
    Jan 2013
    6
    I got my Ipad 4 last week and had the same problem with the wifi connecting to my TP Link router.It connected but then slowed to a crawl a few minutes later.
    I had an old travel router so tried connecting the ipad to that and it worked fine.I couldn't continue to use it because it had limited range being a travel router so I updated the TP Link router to the latest firmware and now the wifi is running perfectly.
    It would seem the Ipad 4 has trouble with some routers unless you update it to the latest firmware.If that doesn't work then you may have to get a new router that works with the ipad.
  1. WiFi connection problem
    By Toonman1 in forum iPad 3 Forum
    Last Post: 10-15-2012, 03:07 PM
  2. Wifi connection problem
    By Dirk123 in forum iPad Help
    Last Post: 04-26-2012, 05:39 AM
  3. Problem with wifi connection
    By fribourg in forum iPad Help
    Last Post: 06-13-2011, 08:04 PM
  4. Ipad 2 Wifi Connection Problem
    By King in forum iPad 2 Forum
    Last Post: 04-19-2011, 06:17 AM
  5. Replies: 9
    Last Post: 04-03-2011, 07:29 AM
apple ipad ios 6.0 connectivity problems 2013
ipad 4 wifi jumps up and down
ipad 4 wifi problem
ipad 4 wifi problem 2013
ipad update connection problems january 2013
ipad.mini.wifi.problems
ipad4
ipad4 slow in wifi
ipad4 wifi issue
ipad4 wifi problem
ipad4 wifi troubleshoot
january 2013 ipad connectivity issues
