Ipad 4 not charging when in use
This is a discussion on Ipad 4 not charging when in use within the iPad 4 Forum forums, part of the Apple iPad Discussions category; Hi, new to this forum. Just wondering if anybody is experiencing something similar. My ipad 4 looses power when in use even when plugged in ...
Results 1 to 10 of 10
    262534
    Nov 2012
    5
    Hi, new to this forum. Just wondering if anybody is experiencing something similar. My ipad 4 looses power when in use even when plugged in to the main. It's never happen to my old ipad 2 and does not happen to my iPhone either. Any thought or suggestion? Tanx
    85546
    475 times
    Aug 2011
    Edmonton AB Canada
    9,514
    The Retina Display is very hungry, particularly when set to higher levels of brightness. It's easily possible that you are drawing power faster than your charger can supply it. For the fastest charge turn your display off as well as any apps that draw power such as GPS, and charge overnight. You can't overcharge. When the iPad has had enough if will stop drawing power.
    Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
    263158
    5 times
    Dec 2012
    51
    That's Not Good.
    Personally I've never experienced that type of bug before.
    The device does pack-a-mean-punch and it does have apps running and GPS,
    So maybe that's why it's draining battery while its charging. Just for a while keep the GPS off
    And close applications if your not using them and see if you encounter that problem if you do
    That's when I suggest you call Apple or a company that repairs the Free of for cheap.
    xTyler
    262534
    Nov 2012
    5
    Everything is turned off. I am only surfing that is and it's very very hot as well even whilst in the case.
    85546
    475 times
    Aug 2011
    Edmonton AB Canada
    9,514
    I find that charging my iPad 2 only just keeps up when I'm using it in my truck. I use MotionX GPS HD, and keep the screen on nearly maximum brightness. I'm not above having music blasting out either, although I find that Music is very light on battery use on it's own.
    85546
    475 times
    Aug 2011
    Edmonton AB Canada
    9,514
    Quote Originally Posted by PrinceKiss
    Could be a duff battery. If it gets that hot, and you're sure the battery consumption is abnormal, you should probably take it in to the Apple Store. Do a backup first, as they may exchange it on the spot. Then you can set up a new one from the backup, and won't have to go through the tedium of setting up from scratch.
    262534
    Nov 2012
    5
    Back up to computer or iCloud which is better?
    85546
    475 times
    Aug 2011
    Edmonton AB Canada
    9,514
    For this purpose, I'd back up to a computer.
    262534
    Nov 2012
    5
    Tanx. Much appreciated
    263456
    Dec 2012
    Sieges
    I think display is eating the battery. Just decrease the brightness and turnoff the wifi when you are not using it.
  1. IPAD 3 not charging
    By U3045901 in forum iPad 3 Forum
    Last Post: 10-12-2012, 10:04 PM
  2. Charging the ipad in the car
    By foothillfanatic in forum iPad General Discussions
    Last Post: 05-20-2012, 09:19 PM
  3. Charging iPad...
    By ahoward1126 in forum iPad General Discussions
    Last Post: 05-09-2011, 04:36 AM
  4. Replies: 7
  5. Charging ipad in usa
    By Radville in forum iPad General Discussions
    Last Post: 10-09-2010, 01:53 PM
apple ipad 4 not charging
ipad 4 does not charge
ipad 4 not charging
ipad 4 not charging on computer
ipad 4 not charging on pc
ipad 4 not charging when connected to computer
ipad 4 not charging while in use
ipad 4 stopped charging
ipad 4 will not charge
ipad not charging
ipad not charging when in use
ipad not charging while in use
