Buzzing sound like a phone brr brr
This is a discussion on Buzzing sound like a phone brr brr within the iPad 4 Forum forums, part of the Apple iPad Discussions category; Hi for the last week at midnight my ipad seems to go off like a brr brr sound about 7 times loudly, even although as ...
Results 1 to 7 of 7
    266760
    Dec 2012
    16
    Hi for the last week at midnight my ipad seems to go off like a brr brr sound about 7 times loudly, even although as far as I am aware I have not set anything up. It's driving my husband mad. Any ideas. Thanks.
    126578
    2 times
    Nov 2011
    137
    Id check into notifications, calandar and reminders and see if anything has changed to notify you. Also look into any other apps that might be able to give you a buzzing notification.
    Moderator
    235421
    119 times
    Aug 2012
    Adelaide, South Australia
    1,885
    In addition to the good advice above, go into Settings>Sounds and within each of the different sounds, see that whatever you have checked is the same sound you are hearing. You may then get an idea what kind of app may be notifying you. Some game apps may come in later with notifications. If it comes on at a set time could it be a clock/alarm app?
    ​Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Everybody please read the forum rules--->
    iPad3 64gig black, PC Windows 8 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
    266760
    Dec 2012
    16
    Hi I appreciate your advice, I have tried making sure all the notifications and alerts for every app I have are turned off. Also I tried to listen to all my sounds and none of them have the same sound, as the brr brr sound that my ipad make at midnight. Also the alarm on the clock which I did not even know I had. It says no alarm set.
    I do not know what else to turn off. This has only been happening the last week. HELP ANYBODY PLEASE..
    Moderator
    235421
    119 times
    Aug 2012
    1,885
    Quote Originally Posted by Gremlin56 View Post
    Let me suggest a couple of more steps, and see how you go. (sorry if you already know this&#128515
    A) Clear out your RAM with apps still hanging around, and this will not harm any app. Double press on your Home button, or do a four-finger upward swipe when you will see all the apps you have used lately in the task bar bottom row. Hold down on any of them until they all start to jiggle. Then press on the"X" on each of them and then: Edit: Should have said minus sign.
    B) Reset (like reboot) your iPad by simultaneously holding down the On/Off and Home buttons until the screen blacks out. Keep holding, ignore any On slider, until the white Apple logo appears. Keep staring at chewed up piece of fruit until your Home wallpaper appears and slide to On. That often helps with a recalcitrant app. Howd'ya go?
    Regards, Andrew🐨
    266760
    Dec 2012
    16
    Hi just want to say Thanks I followed your advice and got rid of all my ram apps and reset my ipad, which seemed to do the trick. So Thanks again from a newbie.
    Moderator
    235421
    119 times
    Aug 2012
    1,885
    No worries. Glad it worked out for you.
  1. Replies: 19
    Last Post: 04-26-2013, 03:30 AM
  2. iPad 3 sound not working but ear phone ok.
    By sujit in forum iPad General Discussions
    Last Post: 09-28-2012, 04:51 AM
  3. Strange buzzing noise!
    By AledJ in forum iPad 3 Forum
    Last Post: 08-09-2012, 02:49 AM
  4. Buzzing sound on my iPad
    By tadmarton in forum iPad General Discussions
    Last Post: 07-28-2012, 02:29 PM
  5. IPad 2 Charging Problem - Buzzing
    By Yorkshire Devil in forum iPad Help
    Last Post: 01-18-2012, 06:20 PM
brr sounds
dell 1570 buzzing noise
ipad buzzing noise
ipad making ringing noise
