Is there any way to connect to internet with out using any wifi connection.
This is a discussion on Is there any way to connect to internet with out using any wifi connection. within the iPad 4 Forum forums, part of the Apple iPad Discussions category; Okay, I am a new iPad user. Most of the time I use it for surfing net. But the problem is WI-FI is not always ...
Results 1 to 10 of 12
    263615
    Dec 2012
    bangladesh
    59
    Okay, I am a new iPad user. Most of the time I use it for surfing net. But the problem is WI-FI is not always available every where. I do travel a lot. So is there any other way to get connect to internet with out WIFI. If there any other way please let me know. Thanks in advance
    Moderator
    131244
    643 times
    Dec 2011
    Regina,Canada
    14,698
    Quote Originally Posted by dreamerdonkey
    If you have a WiFi only iPad, the only way to connect to the Internet is via WiFi. If you tether to a personal hotspot form a device capable of generating one, you can connect to the hotpot with WiFi or bluetooth. If you have a WiFi + cellular iPad, you can connect to the Internet with WiFi or a cellular data connection.
    263615
    Dec 2012
    bangladesh
    59
    The problem is my iPad is WiFi only. And I was mention earlier I travel a lot and bus and trains don't have any WiFi hot spot. So I was thinking is any other way. Is there any device which can give me cellular data connection. Because there are lots of that kind of device are available for android. So if any please let me know. And by the way thanks for reply.
    189610
    Apr 2012
    25
    I carry around a Sprint hotspot to create wifi.
    Merely the observations of an observer
    Moderator
    131244
    643 times
    Dec 2011
    Regina,Canada
    14,698
    Your cellular provider should be able to help you obtain a MiFi device, which is used to generate a WiFi hotspot.
    271731
    Jan 2013
    6
    Quote Originally Posted by dreamerdonkey View Post
    Your android phone can provide cellular data connection.I also got a wifi only model and if I need internet connection on the go I turn my android phone into a wifi hotspot using the free app called Foxfi.This is assuming that you have a data plan for your phone.
    263615
    Dec 2012
    bangladesh
    59
    Thank you all. Really appreciate your help. I turn my iPhone in to a router and create a WiFi hot spot. Thanks again to all for your suggestion.
    278428
    Feb 2013
    Türkiye
    Lightbulb
    Hi,
    Other than wifi-hotspot, is it possible that I can share my internet on iPhone 3Gs(tethering) and connect via "bluetooth" (after pairing the ipad mini with iphone 3Gs)
    i hope it is possible, because i'd prefer bluetooth to wifi-hotspot for battery consuming purposes..
    Moderator
    131244
    643 times
    Dec 2011
    Regina,Canada
    14,698
    Quote Originally Posted by muratefendi
    Hi,
    Bluetooth tethering has already been mentioned in this thread, they both consume a lot of battery power from the phone generating the hotspot.
    278428
    Feb 2013
    Türkiye
    i was hoping, bluetooth tethering used less power than wifi hotspot but anyway, i will go with that option
    thanks for the reply
  1. Can I connect to internet without wifi?
    By supersue in forum iPad Help
    Last Post: 09-06-2012, 01:05 PM
  2. Replies: 0
    Last Post: 11-28-2011, 12:49 PM
  3. Cannot connect to Internet using WiFi or 3G
    By thomaswhittaker in forum iPad Help
    Last Post: 06-10-2011, 02:10 AM
  4. Replies: 3
    Last Post: 06-04-2011, 08:16 AM
  5. Replies: 3
any way to connect to internet with ipad
can you use a hotspot device with an ipad4?
can you use wi fi without internet connection
ipad4 connect internet without wifi
is there any way to connect to the internet using wifi when home
is there anyway to connect an ipad to internet without wifi and data plan?
need internet but only wifi on ipad mini any way other than tethering
