itunes help
This is a discussion on itunes help within the iPad 3 Forum forums, part of the Apple iPad Discussions category; ok i have the latest itunes install i'm trying to add music from my pc to my ipad3 i have the playlist showing in itunes ...
Results 1 to 2 of 2
Thread: itunes help
    258245
    Nov 2012
    12
    Question itunes help
    ok i have the latest itunes install i'm trying to add music from my pc to my ipad3 i have the playlist showing in itunes but for some reason i can't find a way to transfer it to the ipad
    any help or advice thanks
    iPad Addict
    168139
    51 times
    Feb 2012
    Brisbane, Australia
    1,143
    Have you clicked on your device in the top right hand corner and selected the Music tab, scroll down and check your playlist and then sync. You should have Manually manage your Music checked on the Summary tab first.
    dhewson777
    Brisbane, Australia
    iPad 2 , iPhone 4, MBA 11"
    Yes, I have windows PCs as well! (too many to list)
  1. Replies: 5
    Last Post: 05-20-2012, 09:17 PM
  2. Replies: 2
    Last Post: 04-26-2011, 06:38 AM
  3. In iTunes under devices i select iPad then audio and iTunes crashes
    By emmett in forum New Member Introductions - Site Assistance
    Last Post: 04-25-2011, 07:16 PM
  4. Replies: 11
    Last Post: 09-23-2010, 06:29 PM
  5. Replies: 0
    Last Post: 06-18-2010, 09:31 PM
