Problem with facetime
This is a discussion on Problem with facetime within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Please help...I have a working Internet connection....I use Internet using my Nokia mobile via Bluetooth...but when I try to make a FaceTime call, I get ...
Results 1 to 9 of 9
    255853
    Nov 2012
    Bangladesh
    45
    Please help...I have a working Internet connection....I use Internet using my Nokia mobile via Bluetooth...but when I try to make a FaceTime call, I get a message saying connect to a wifi network to use FaceTime...when I use speed-test app to test my net speed..it says that I have a wifi connection...but why this problem with FaceTime? Please give me a solution to this problem...
    Attached Thumbnails Attached Thumbnails Problem with facetime-image-1111670811.jpg
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,467
    Unless you are on iOS 6 AND your service provider has allowed for FaceTime over cellular, it is only available over wifi.
    A workaround is to use Skype, which works over cellular.
    Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro |
    255853
    Nov 2012
    Bangladesh
    45
    I have a wifi only iPad and 2g net and my iOS is 6.0.1...and as my net is 2g I don't think that my service provider has any control over FaceTime...and I want to make FaceTime calls over Internet...I don't have 3/2g in my iPad...I use Bluetooth net...which is recognized by speed-test as a wifi net...and thanks for your response...
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,467
    Very strange. I have used FaceTime in the manner that you are describing, but with an iPhone 4 providing the hotspot. It works. That is why I thought it must be a service provider issue, since some can and do block FaceTime. Mine does not.
    Sorry I couldn't help.
    255853
    Nov 2012
    Bangladesh
    45
    It's okay...actually it doesn't matter even if the problem is fixed...I only know one person who has a iPhone and has activated FaceTime....I don't need to video call him...and your one works because you made a wifi hotspot using your iPhone, I assume...you didn't connect via Bluetooth...
    85546
    473 times
    Aug 2011
    Edmonton AB Canada
    9,467
    Probably not. I accept the defaults when I make the hotspot connection, so it's likely wifi, no Bluetooth.
    255853
    Nov 2012
    Bangladesh
    45
    And that's why you were able to make FaceTime calls...because you use wifi hotspot...but I use Bluetooth...
    229446
    Jul 2012
    10
    For no apparent reason, Facetime has stopped working. I have tried all the posted suggestions and its still dead. I wonder if anyone else has the same problem or if someone else has a solution to this issue. Thanks.
    229446
    Jul 2012
    10
    Problem solved. Go to settings. Scroll down to FaceTime. Put OFF then ON again. Follow the prompt if asked to be registered using apple ID. Thats it.
  1. Facetime problem
    By dengriff666 in forum iPad 3 Forum
    Last Post: 10-12-2012, 04:02 PM
  2. iPad 3 FaceTime problem?
    By morag12 in forum iPad 3 Forum
    Last Post: 09-29-2012, 11:36 PM
  3. Problem with FaceTime.
    By johnnie robison in forum New Member Introductions - Site Assistance
    Last Post: 08-25-2012, 06:55 AM
  4. Facetime problem
    By melsnel in forum iPad 2 Forum
    Last Post: 07-10-2012, 11:14 PM
  5. Facetime problem
    By blueridge in forum iPad 2 Forum
    Last Post: 03-15-2011, 12:32 PM
facetime call over bluetooth
facetime ipad3 problem
facetime not working
facetime over bluetooth
facetime problems
facetime problems ipad 3
ipad3 facetime problem
iphone 5 facetime over wifi problems
problems with facetime on ipad 3
