How do I delete firmware 6.0.1 that i downloaded but havent installed?
This is a discussion on How do I delete firmware 6.0.1 that i downloaded but havent installed? within the iPad 3 Forum forums, part of the Apple iPad Discussions category; As the title says. I bought an ipad 3 3g with 5.1.1. firmware and just jailbroke it today. I noticed that 6.0.1 is ready to ...
Results 1 to 10 of 13
    257011
    Nov 2012
    illinois
    As the title says. I bought an ipad 3 3g with 5.1.1. firmware and just jailbroke it today. I noticed that 6.0.1 is ready to install through ota. How do i delete that file to get back that space its taking?I've tried looking through a bunch of folders but couldnt find it or not sure what to look for.I know i cant restore because i do not have my blobs saved through cydia or anywhere.
    thanks for your help.
    Moderator
    131244
    641 times
    Dec 2011
    Regina,Canada
    14,686
    Quote Originally Posted by adrian2pm
    I'm afraid it can't be deleted. All you can do is ignore it until such time as an iOS 6.0.1 jailbreak is released.
    13576
    749 times
    Aug 2010
    Western NY state (USA)
    9,312
    I don't think anyone has ever found where that update is (I'm not even sure the update is actually on the iPad - it just might be code to initiate the update when you press on that line in your Settings app). Of course, I'm perfectly willing to be corrected...
    So, my suggestion is to ignore it and NEVER press that update line. I am in the same situation and I have a couple of Cydia tweaks installed to help me. They are (1) "No Update" - stops your iPad from looking for and downloading the update (with this tweqk installed, you could press the update in Settings, but nothing will happen) and (2) "noOTA bade" - removes the red badge from the Settings icon. Just makes it less annoying than to have a badge you can't clear.
    Those two tweaks will help you avoid the whole update mess. And, with careful management of your iPad (e.g. only install known safe tweaks), you should be fine on iOS 5.1.1.
    Hope this helps ... somewhat.
    257011
    Nov 2012
    illinois
    thank you all. i am going nuts looking for that file. i will try those tweaks you mentioned. thanks again.
    257110
    Nov 2012
    6
    Hi,
    I am a new iPad user. I have the standard 3 model, it is not jail broken.
    My question is this.... I also have the 6.01 update waiting in my settings. I only will install it if the wifi problems have been overcome with this release since 6.0 would not work with many routers, notably netgear which I have.
    Anyone know if it is fixed or again how can it be deleted from an unjailbroken pad?
    Thanks for any replies!!
    Moderator
    131244
    641 times
    Dec 2011
    Regina,Canada
    14,686
    Quote Originally Posted by beachutman
    Hi,
    As stated earlier in this thread, you can't delete a downloaded, but not installed update. You cannot remove the update notification from settings.The wifi problem was generally with older routers that hadn't been updated.
    257110
    Nov 2012
    6
    Quote Originally Posted by scifan57
    Thanks for that. I have an old router but it works perfectly with all my other pc's.
    Guess I had better wait till the next release from apple. Not impressed by this at all! That download which I didn't want she's up ver a gig of space which is a lot on a 16g model.
    I suppose if I do a full restore it will just download itself again :/ ?
    257110
    Nov 2012
    6
    Thank you! If I do a reset on the iPad I presume it will just download it again? It uses up over a gig on a 16g iPad:/
    257110
    Nov 2012
    6
    Sorry!! Posted twice . Not used to the interface yet!
    Moderator
    131244
    641 times
    Dec 2011
    Regina,Canada
    14,686
    The problem is not with the Apple iOS update, but an older router that needs updating. If you update your router, is should work with your PC's and your iPad.
    As long as your iPad is not on the current version of iOS, you will always get onscreen reminders to update. If you are already on iOS 6, the update to iOS 6.0.1 should be less than 60MB, not over 1GB.
  1. how to delete file downloaded from safari
    By gatemaze in forum iPad 3 Forum
    Last Post: 10-05-2012, 06:19 PM
  2. How to delete installed aps from my ipad?
    By martinsm007 in forum iPad 3 Forum
    Last Post: 08-16-2012, 06:11 AM
  3. How do i delete the installed application?
    By thain8270 in forum iPad FAQ
    Last Post: 08-30-2011, 04:52 AM
  4. Downloaded app won't download or delete
    By lalacam in forum iPad Apps
    Last Post: 07-22-2011, 01:39 AM
delete apps off 6.0.1 sofware
delete update 6.0.1
how can i delete firmware 6.0.1 off my iphone
how do i remove apps in ios 6.01
how do i uninstall 6.0.1 from iphone
how to erase update 6.0.1
how to stop software update 6.0.1 on ipad
installed firmware 6.0.1
ipad 2 won't update to 6.0.1
ipad wont install update 6.0.1
remove software update notification ipad
remove update notification ipad
