How long does it to charge ipad3? Do I have a problem?
This is a discussion on How long does it to charge ipad3? Do I have a problem? within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Was wondering. iPhone 4 charges upto 100% in few hours. iPad 3 charges 7-8% per hour. So from 0 to 100% takes 14 hours to ...
Results 1 to 10 of 10
    244712
    Sep 2012
    IWorld
    13
    Was wondering. iPhone 4 charges upto 100% in few hours. iPad 3 charges 7-8% per hour. So from 0 to 100% takes 14 hours to charge the battery. Is this normal?
    Device has been in use for about 2 months.
    Like right now as typing this and plugged into wall, charge dropping (3% so far). So in conclusion wifi connection taking more power then the wall outlet can provide?
    Someone please give me answer before I complain to store that sold me this. Or is this normal?
    Kinda understandable as if battery life 10 hrs and 14 hrs to charge it makes exatly hrs in a day.
    Moderator
    131244
    635 times
    Dec 2011
    Regina,Canada
    14,642
    Quote Originally Posted by Antsu
    Are you using the charger that came with your iPad or your iPhone charger? An iPhone charger will take a long time to charge an iPad and your iPad may lose charge if you try to use it at the same time.
    If you are using the iPad charger, 14 hours is too long for a normal full charge. In this case, you may want to have it checked out at an Apple store as it's still under warranty.
    39523
    16 times
    Lincoln
    182
    Yeah, make sure you are using the charger block that came with your ipad(should be a 10 watt charger, might not say iPad on it though). Mine takes about 5 hours to charge from flat to 100%. I have a 3 that is a little over 2 months old. My iPad 2 was faster to charge at about 3 hours.
    My 3, I just use throughout the day and overnight charge it. That way it's long charge doesn't cause me grief.
    244712
    Sep 2012
    IWorld
    13
    Yes. Using the iPad plug. Also if connect to iTunes on pc iPad says that not charging. iPhone does charge if connected to pc. Should iPad do the same? Or is pc voltage too litlle to charge iPad ?
    Moderator
    131244
    635 times
    Dec 2011
    Regina,Canada
    14,642
    The iPad will charge very slowly if connected to the USB socket on a computer. Most USB sockets do not supply enough power to do more than trickle charge an iPad while it's turned off.
    244712
    Sep 2012
    IWorld
    13
    Yeah, but says that NOT charging at all. Replacing the battery icon on top... ITunes works ok so not wire. And also iPhone works + charges.
    Moderator
    131244
    635 times
    Dec 2011
    Regina,Canada
    14,642
    Even though it says not charging, it's actually charging very slowly.
    244712
    Sep 2012
    IWorld
    13
    Ok. Thought that it could be related to long charging time via wall plug. As above mentioned take 5 hrs to charge. This take 14 hrs. Shall call to shop that bought this from.
    178077
    Mar 2012
    Brisbane, QLD
    91
    Keep in mind the major differences in the batteries between the iPhone 4, iPad 2 and iPad 3.
    iPhone 4 Battery: 5.25 Wh (1,420 mAh)
    iPad 2 Battery: 25 Wh (6,579 mAh)
    iPad 3 Battery: 42.5 Wh (11,560 mAh)
    The larger the battery, the longer it will take to charge.
    257178
    Nov 2012
    Derby
    9
    Try changing the cable from the charger to the USB. I had a similar problem, and changing my cable helped.
  1. Replies: 4
    Last Post: 03-27-2012, 10:22 AM
  2. How long it takes to charge the iPad2?
    By bat0nas in forum iPad Help
    Last Post: 07-07-2011, 03:07 PM
  3. How long does a charge last?
    By PNova in forum iPad General Discussions
    Last Post: 06-10-2011, 12:39 PM
  4. Why does it take 5so long for it to charge?
    By Tapmyapple in forum iPad 2 Forum
    Last Post: 04-13-2011, 08:54 AM
  5. Batteries-how long to charge
    By CMFox in forum iPad Help
    Last Post: 06-13-2010, 01:07 PM
how long does an ipad 3 take to charge
how long does an ipad take to charge
how long does ipad 3 take to charge
how long does it take for a ipad 3 to charge
how long does it take to charge a ipad 3
how long does it take to charge an ipad
how long does it take to charge an ipad 3
how long does it take to charge ipad 3
how long does the ipad 3 take to charge
how long it takes to charge ipad 3
how long should it take to charge an ipad
how long to charge ipad 3
