Thanks. I am not sure if it is the stylus, because it did not do it before.
If I come across any solution, I will let you know.
Going to try and wipe the iPad clean and restore everything
This is a discussion on Problem! When drawing using a stylus within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Thanks. I am not sure if it is the stylus, because it did not do it before. If I come across any solution, I will ...
